46yblock
Visits: 7.8K
Are the earler truck mounts the same as the Bird's? Comparing pictures of the T-bird mount to mine I cant see any difference.
aussiebill
Posts: 1.8K,
Visits: 11.4K
If you are referring to the front engine mount, the truck and t bird are the same. regards bill.
46yblock
Visits: 7.8K
This is the mount Ive been wondering about:
bloodyknucklehill
Last Active: 14 Years Ago
Visits: 2.2K
hey mike.. i have two truck motor mount plates and neither of them look like that.. is that from a T-bird?
DustinSouthern Oregon Y's Guy  http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
46yblock
Visits: 7.8K
The pic is from ebay. but I have one just like it now, and have had two others previously. They must be from the 57 or 56 and earler trucks. The mount when specified for a Bird often gets at least twice the price as the truck. There were at least two truck mounts that were different than this, which came out in the later years. That would be what you have Dustin. (I sent a check today). Mike
John Mummert
Visits: 7.5K
Mike, the mount you pictured will fit 54-55 trucks and 55-57 T-Birds. It won't fit 56 trucks because that was the first year a crankshaft damper was used in trucks. The damper ring of a passenger car type damper will hit the reinforcing ribs. Car and truck dampers were the same from 56-on. The T-Bird damper sticks out far enough to clear the ribs. I have seen factory pictures of T-Bird engines that appear to use the mount you show but when the new mount for the 56 truck was made with the spread ribs the T-Birds probably got it too
46yblock
Visits: 7.8K
Interesting info John. Thanks, as I've been seeking it for a while. I think I sold the other two on the bay as fitting early Ford trucks and T-birds. No negative feedback, but too often the mismatch doesnt show up for the buyer until weeks or months after the purchase.
bloodyknucklehill
Visits: 2.2K
hey mike one of the mount plates i have is a one i pulled out of a 292 that was retro-fitted into a 54 F-100.. might be what you need.. if you need pics I can get them for you to double check..
46yblock
Visits: 7.8K
Thanks Dustin but I dont need much, except some new lifters, a bunch of JMs offerings, and a '54 car  . Just trying to get rid of some extra parts that are hanging around.
WILD WALFORD'S56
Visits: 248
The orange mount pictured is from a 1956 ford truck. I have several,and look the same. Bill
Always buying and selling 1956 ford trucks and parts...Ohio
