Duplicate Keys for y-block era cars???
Posted By Big6ft6 16 Years Ago
Big6ft6
Posted 16 Years Ago
Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)Supercharged (272 reputation)
Posts: 241, Visits: 347
My 56 ford only came with one set of keys which makes me really nervous....what are the options for getting copies made of the keys I have?
Nate - Madison, Wisconsin
56 Ford Customline Sedan
Posted 16 Years Ago
Last Active: 4 hours ago
Posts: 3.7K, Visits: 322.9K
Check your local hardware or home repair stores, if they have blanks, they can cut new keys from your old ones.  If they don't have blanks, the T-Bird and early Ford vendors have blanks.  Local locksmiths usually offer this service too.
DANIEL TINDER
Posted 16 Years Ago
Last Active: 8 hours ago
Posts: 1.7K, Visits: 154.1K
Local ACE store I frequent cut the FoMoCo blanks I purchased (CASCO) and brought in for free, but it took three trips to get them right, so chose someplace close.
6 VOLTS/POS. GRD. NW INDIANA
Posted 16 Years Ago
Tee-Bird.com and Macsantiqueautoparts has repro key repro blanks..About $2-$3 each.
gritsngumbo
Posted 16 Years Ago
Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)Supercharged (168 reputation)
Posts: 153, Visits: 2.2K
DANIEL TINDER (10/28/2009)
I've found it's much easier, quicker (and ultimately cheaper) to have a GOOD local locksmith cut keys. We have a local shop that's been here for years, and I've never gotten a bad cut from them. Prior to finding out about them I used to have to make at least two trips back to the "hardware" store to have keys re-cut.
Gerald Ingram aka "Gritsngumbo"
Monroe, LA
LITTLE RED: 64 Ford F100 Short Bed Styleside
BIG RED: 63 Ford F100 Long Bed Unibody
BBW RED: 61 Ford F100 BBW Long Bed Custom Cab Unibody
BIG “UN: 63 F250 Longbed Flareside
CREW CAB: 63 F100 "Stageway" Crew Cab w/Long "Wrong" Bed
Bob's 55
Posted 16 Years Ago
Posts: 287, Visits: 1.0K
Worse comes to worse complete matched ignition/door lock tumbler/keys sets are available from various venders. Very easy to change out if your original set is in marginal condition...
BOB
Big6ft6
Posted 16 Years Ago
Thanks Guys!  lots of options sounds like, consider this question ANSWERED!Smile
DANIEL TINDER
Posted 16 Years Ago
Bob's 55 (10/28/2009)
Might be worth considering to change old ignition tumbler BEFORE it breaks, as I had a really hard time getting mine out (button function that releases it normally had failed). Naturally, it broke while on a long/distant tour, so had to hot-wire for every start.
Posted 16 Years Ago
Just some added info on ignition keys & door locks. Old ones are often dirty inside & the keys are too. Eventually they start giving grief. Often if you use solvent, initially on the key, and insert the key repeatedly & wipe it on a clean light rag, you can clean the lock. After a few applications, possibly go to methyl hydrate to avoid flooding the ignition with solvent. I fixed the ignition on my 57 car that way. it just takes patience to do it. The ignition barely worked when I got the car.
