Last Active: 11 days ago
If the cam and lifters are being reused in the same block, no issue as long as the lifters are kept to the lobes that they are matched to. When changing blocks, there’s always the chance that the lifter bores do not align the same from block to block which means the cam could still go bad with the original lifters as a new wear spot on the lifter is taking place. Just food for thought. My recommendation for used camshafts in blocks they were not originally run in is to always use new lifters in those instances.
Glen Henderson
Posts: 1.4K,
Visits: 7.5K
Paul, my thoughts also, don't make since to do otherwise.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posts: 3.3K,
Visits: 238.8K
For arguments sake... obviously if you have a good cam without the original lifters, new ones will be needed. However, if you have that same cam with the original lifters, that you are sure have been kept properly in order, why would you break in new lifters on that cam?
RB
Visits: 16.7K
Frank, The tranny blew the gasket between the pump and case. I found out it is not uncommon.. Just about have it back together, too bad weather has turned to crap.. doubt I'll get out to the track any time soon.
Posts: 3.0K,
Visits: 8.7K
RB, Wrong place for this, but what did you find on the tranny in the Drag Bird after Columbus? Frank
RB
Visits: 16.7K
Butch did not see any email message... Send it directly to me at brechlrl@charter.net
Butch Lawson
Last Active: 2 Weeks Ago
Visits: 20.9K
RB, Sent you an e-mail. Butch
Butch Lawson Manchester, TN
Butch Lawson
Visits: 20.9K
When I talked to the tech at Lunati he told me that the Lunati division had been sold by Holley to someone else prior to them taking bankruptcy.
Butch LawsonManchester, TN
RB
Visits: 16.7K
Butch, send me an email.. maybe i can trade you a cam you can use
gentz
Last Active: 16 Years Ago
Visits: 569
always use new lifters.. used or new cam....
If it aint broke, lets modify it!
1962 Galaxie 500 Town Victoria 4dr. 292 with a nice mild cam.
Salinas California.
