Posts: 3.6K,
Visits: 497.6K
Mercury Valve Cover (1) good condition, has some pits $15
Valley cover, good condition, car. $15
14 inch rims off a 80 Granada (2). Very good condition $20 ea., 2 for $35
55/57 TBird Door access panels, fibreglass $20 ea. Excellent condition.
YBlock generator mounts for car. (3 pieces) very good condition $15
Dual Diaphram fuel pump for YBlock. Good vacuum for wiper, can't tell on fuel side (bad bowl gasket. Probably should be rebuilt $15
YBlock Flywheel for 10 inch clutch. Good condition. No ring gear on flywheel, (I have one but its chewed a little and will go with the flywheel) $20.
Fordomatic tube and dipstick. Very good condition. Not sure of year, but may have come off my 54. Should be the same as other years? $20
Heads - C1AE. Probably needs valve job $35 pr.
Add for shipping. Discounts on multiple items. Pics available. Items located in New Jersey.
Posts: 2.0K,
Visits: 129.2K
Mark, does that valley cover have the provision for the rear crankcase tube? What is a "car" valley cover? I did not know there was a difference.
Posts: 3.6K,
Visits: 497.6K
Daniel Jessup (10/3/2009) Mark, does thatvalley cover have the provision for the rear crankcase tube?
What is a "car" valley cover? I did not know there was adifference.No provision for rear crankcase tube (TBird)
Posts: 1.0K,
Visits: 4.5K
Paul , Send me a pic of the door access panels to wpccgrad@hotmail.com Thanks Earl Dagenhart
55Birdman Hickory NC
Visits: 1.3K
Paul- If the fuel pump is a AC pump, I'll take it- /Duck
BOO- YA!!!
Posts: 3.6K,
Visits: 497.6K
Duck - sent you PM. The pump has no manufacturer's markings.
Last Active: 39 minutes ago
Visits: 322.6K
Duck: If Paul can't help you with a fuel pump, give me a shout. John
Visits: 1.3K
John- Incoming.... /Duck
BOO- YA!!!
