Posts: 1.0K,
Visits: 4.5K
WTB 12 V. instrument cluster or parts for 55 tbird. i know bird had 6v want to change to 12v. thanks  tbirdman
55Birdman Hickory NC
Visits: 497.8K
The 56 Birds had 12 volt gauges. They should fit the 55 ok. You can use the 55 gauges with 12 volts by using the Ford voltage regulator for gauges that came on all Fords from 1957 to the 80's. Available from parts stores and probably from Ford. The only thing I am not sure about is the oil and charge idiot lights. I don't know how those will work with the voltage regulator.
Visits: 12.3K
Voltage regulator is only for gauges, between gauge and power supply. Those idiot lights needs 12 volt bulbs, nothing else. Tero from Finland
Tero from Nurmijarvi, Finland56 Country Sedan, 61 F-100, 61 F-600, 55 F-620, 52 Mercury
Visits: 20.6K
a friend of mine converted his 55 ford from 6 volt to 12 volt and what we did was use the back side of 56 gauges the electrical part and mounted them to the 55 gauges.that way you have the orig. look
