Visits: 4.4K
Hi.
I need the pedal crank which connects to the linkage from the accelerator pedal, is clipped/bolted to the firewall and supported on the rear of the engine.
I have an original linkage for the two barrel setup but want to fit a four barrel - eventually I will fit a Blue Thunder manifold, though at present I am using a 56 four barrel manifold.
I know I can cut the lever off the crank I have, modify it and rotate it but if I do that it ruins it for someone else if they want to fit the original two barrel setup. I would prefer to fit the original four barrel linkage. I have the mechanism which bolts to the manifold and connects to the carb. My car is fitted with the Fordamatic which makes using the original setup a much better option.
Can anyone help.
Regards
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
Last Active: 9 hours ago
Visits: 32.6K
Rick! Paul has an add further down for some cars he is selling.The Town Sedan with the "P " code was 4bbl if the gas pedal linkage is still in it.Maybe he will sell you some parts.PW42
Visits: 4.4K
Thanks for that I will check it out.
Regards
