Daniel Jessup
Posts: 2.0K,
Visits: 130.8K
I decided to po st in this forum since I am not really buying or selling any carb kits to posters, but I need one myself.For the 55-56 Holley teapot carbs, what rebuild kits are the best to buy? It has been about 15 years since I purchased one - and that was one from Borg Warner I believe. Ideas? Opinions? Dan
Doug T
Visits: 2.6K
I expect "The Carburetor Doctor" in canada can help you. Google him and find his web site. I have been fully satisfied with the Ford 4100 kit I got from him last year.
Posts: 7.4K,
Visits: 205.8K
Doug. Did the carb kit you received come with a new secondary diaphram?
Doug T
Visits: 2.6K
Ted Yes it had a new secondary diaphragm. As far as I remember I did not reuse any old elastomeric parts. The carb I have was a freebee and had been "reworked" a little. The Carb Dr web site had info from the part number which identified the carb as an obscure Mercury FE carb from the mid '60's. It is a 1.13 venturi and I would slightly prefer a 1.08 but not enough to make much fuss over it and of course the price was right!!
Doug T The Highlands, Louisville, Ky.
Daniel Jessup
Posts: 2.0K,
Visits: 130.8K
thanks fellas - that carb doctor site is pretty nice. I will give them a call on Monday. Dan trying to get a test stand Y block ready for the CVA show late this month.
55Birdman
Posts: 1.0K,
Visits: 4.5K
Steves carburetor shop. www.stevescarb.com in NJ 210-935-3499
55Birdman Hickory NC
Posts: 7.4K,
Visits: 205.8K
Doug. Thanks for the info on the 4100 carb kits. Any one have an idea who has the best pricing for the secondary diaphrams for the model 4000 Holleys (Teapots).
Posts: 3.0K,
Visits: 8.7K
Pony must have a source, mine came with a new one.
DANIEL TINDER
Last Active: 15 hours ago
Visits: 154.1K
Re: Carbs. Disassembled & cleaned my Pony teapot a couple years ago, and now that I have a NOS brass float needle/seat, and the new O-ringed cover, will put it back in service soon.
I stored it in an air-tight bag, but fear the gaskets have likely shrunk. The expert at Pony claims only another rebuild will suffice, but I am hard-headed/suspicious enough to try it anyway. I thought maybe soaking it in a bucket of gas for a few days....? Any suggestions?
6 VOLTS/POS. GRD. NW INDIANA
Posts: 3.0K,
Visits: 8.7K
Dan, Pull it apart and soak the gaskets in water.
