Wanted - BELLHOUSING FOR 272 to T10 TRANS.
Posted By 39 PU Y 16 Years Ago
39 PU Y
Posted 16 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Last Active: 14 Years Ago
Posts: 6, Visits: 45
I want to install my 1962 T10 trans. behind my 272 motor. Any Bellhousings?
Posted 16 Years Ago
Last Active: 8 hours ago
Posts: 3.7K, Visits: 322.2K
If it is a Ford T10, it should bolt directly to a stock Y bellhousing.
Posted 16 Years Ago
Last Active: Today @ 2:50:31 AM
Posts: 7.4K, Visits: 205.0K
Helps to know where you are at for traveling or shipping purposes.  If you’re in my neighborhood, I have a pile of them and they go cheap but don’t ask about shipping as I’ll not ship one.  They are plentiful enough that there should be one within easy traveling distance of you once you find where they are.
39 PU Y
Posted 16 Years Ago
Thank You both for the info and encouragement!
Its a Ford T10. The bell I have is for a truck so it won't work. Maybe someone in So. Cal. has one?
Posted 16 Years Ago
If no luck here, try John Mummert Y-Block in El Cahon CA 619-596-0312.
57FordPU
Posted 16 Years Ago
Posts: 726, Visits: 73.6K
39 PU Y
I sent you a PM.  Please respond if you still need a bellhousing.
BurnsRacing981@gmail.com
39 PU Y
Posted 16 Years Ago
I was out of town most of the week. No stock bellhousing yet.
Dennis Gidcumb
Redlands, Ca.
39 PU Y
Posted 16 Years Ago
I found a good truck bellhousing at a local salvage yard. It has the T10 pattern and bolted right up to the transmission. Now I am thinking about the clutch disk and input shaft length.
moving right along.... Dennis
