Good compression numbers, plus more leaky head gaskets
Posted By 46yblock 16 Years Ago
46yblock
Posted 16 Years Ago
Posts: 1.2K, Visits: 7.8K
Yesterday I checked the cranking compression of the new 292.  The numbers were good.  170 to 175 on all cylinders but one.  The oddball was 165, and the same combustion chamber that has some pitting from junkyard corrosion.  Cam is an  Isky E-4 kind of detuned with 1.43 rockers.
The only indication of detonation or preignition came during cam breakin.  Engine temp got up to 210 and when I shut of the ignition there was diesel run on.  Plugged up some vacuum leaks and high heat stopped.  Also made sure to never turn off ignition on the heated engine with idle set at 2000.  Gas has been mid grade 89 octane, 6 degrees initial.  250 miles accumulated on build.
Now for the one remaining problem.  Both head gaskets are seaping coolant.  Nothing in oil or chambers which is very good, but there is a small amount coming out the outside edge, leaving a 50 cent size puddle on the floor overnight.  Gaskets are the new design felpro.  New studs in heads torqued/untorqued/retorqed 3 times on assembly.  Deck and heads resurfaced during buildup.  Studs and nuts oiled before assembly.
Talked to a machinist friend and he was very surprised that they leeked.  He said he would put in a can of Stop Leak and it should take care of it.  I think the problem is due to those damn steam holes between the two center cylinders of the C2AE block.  The 113 heads dont have the holes, so coolant may be dribbling down and out at that point.
mctim64
Posted 16 Years Ago
Posts: 2.4K, Visits: 5.0K
Did you do your break-in with coolant or water?  I do my break-ins with water to help seal up little leaks like that also we put a cube of "block sealer" in every engine we build to seal expansion plugs, water pumps and such.  I don't think it would be the steam holes but I could be wrong, I am sometimes you know. Tongue
46yblock
Posted 16 Years Ago
Tim,
It is good to know you are familiar with radiator/block sealer.  I'm not and was reluctant to use it.
Picked up some today.
Breakin was and is being done with antifreeze solution.  Should it be drained after the sealant is added
and leaks have stopped?
Mike
mctim64
Posted 16 Years Ago
What kind of radiator sealer are you using?  I don't recommend them all.  What we put in the rebuilds are a little cube called "Well tight cubes" you might be able to get it from your machine shop. I wouldn't recommend something like "Bars leak" especially in a fresh clean radiator, it plugs everything including radiator.  I would say just drain the coolant out and run water for a while, even without putting the sealer in and see what happens.  Wouldn't hurt, as long as it's not freezing up there.
Posted 16 Years Ago
Last Active: 27 minutes ago
Posts: 7.4K, Visits: 205.7K
46yblock (5/28/2009)
You said studs and nuts were used so I'll ask the obvious question.  Were the top row of studs all the same length or two different lengths?  The longer studs should go on the outboard ends.  Did you put the nuts on the studs without the washers first to insure that the nuts would pull the heads down sufficiently?  If you are running out of threads before the final squeeze is put on the head gasket, then a coolant leak can be present while not being a problem for cylinder pressure sealing.
46yblock
Posted 16 Years Ago
Ted, the studs are ARP, so they have the same thread top to bottom.  4 longer studs were packed separately and I'm certain they were properly placed in the ends.  The torque was 73 lbs. because there seemed to be a little flexibility in the torque spec called for by ARP, with the top being 80 lbs.
Today I retorqed the PS head to 80, gaining a slight amount of wrench movement.  Tomorrow I will tackle the more difficult DS.  If still leaking, Tim's suggestion of water is next, then some kind of sealer.  The one I picked up is Prestone.  This is what they say about it on their web site:
"Super Radiator Sealer takes sealing performance to a higher level.  Its unique combination of natural and synthetic components provides the ability to seal leaks up to 0.016” X 0.5”.  What makes this possible is the size, strength, and durability afforded by fibrillated Kevlar® particles, the same materials in bullet proof vests.  Super Sealer’s particles have been chosen to seal even large leaks without interfering with the flow through the radiator and heater core tubes."  So since it is FIBRILLATED it has to be good Wink.
Today I mentioned the situation to a car enthusiast friend.  He said years ago he cured a badly leaking radiator with a small bottle of Cayenne pepper poured into the top of the radiator.  But it isn't fibrillated and probably would produce engine backfires Tongue.
Mike
Fordy Guy
Posted 16 Years Ago
Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)Supercharged (106 reputation)
Posts: 96, Visits: 290
  I remember when I was in my teens, I had an old 52 Chevy 5 window pickup with a worn out 216 six in it. The side of the block had a small crack in it and seeped with just water, and really seeped if you tried to use anti-freeze. My dad said he could fix the leak by using 2 eegwhites. We drained the engine and purged all the anti-freeze out so it was using just water and he put the eggwhites in the cold system and I ran the engine for a couple of days and it DID stop the leak! I drained the system later and put in anti-freeze in and it didn't leak. I ran that old engine until There wern't any more shims to take out of the caps. We built a GMC 271 six to replce it later. Sorry to throw around the "C" word so much, just recalling some good old times.     Bud
Bud in Northern Arizona on route 66 in Winslow (standin' on the corner)
If you're American, buy American
631/2 Galaxie 500XL 406   55 T-Bird
46yblock
Posted 16 Years Ago
Egg whites sound better than Chilie!
46yblock
Posted 16 Years Ago
The leaks appear to have stopped after the 80 lb torqueing.  Took the truck for a 40 mile run and no puddles after two days.  I hadnt wanted to use that much pressure due to a problem deck bolt hole, but it looks like it will hold.  During the drive it felt like the engine was more responsive than previously.  I checked 3 or 4 of the rockers when doing the lash, and they each needed .003 more lash, so maybe compression is up even a little higher.
While driving, the oil pump I asked about in another thread started doing weird things.  Beginning of the trip pressures were 24 hot idle and 48 hot cruise.  Then after 20 miles the pressure dropped back to pre spring shim levels, then 10 miles later back up to 48 cruise.  So I changed the pump out, now have 60 psi cold idle and 72 psi cold 2000 rpm.  Seems like a lot of pressure for a regular output pump but I'm not complaining.
Hopefully now all the major bugs are worked out.
56 big window
Posted 16 Years Ago
Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)
Posts: 87, Visits: 263
John Memmert has a newly designed head gasket for y blocks that may eliminate your problem should it reoccur . Hopefully it will not
