Visits: 4.4K
I am chasing a '57 up distributor with the dual advance, vacuum and mechanical.
I need the model with the bent arm on the Vacuum unit as I have a Accel kit to fit.
The distributor I have seems to be an odd bod as it has a straight arm on the advance and the Accel unit fouls its operation. This distributor is also dual advance but may have been only released in OZ!!!
Hope someone can help me.
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
Posts: 3.6K,
Visits: 497.5K
I sent you an email on a distributor I came across today. I don't know if its the one with a bent vacuum arm that you want. Yours for postage. If you want it, I will contact my friend who has it and check the arm. Don't know about condition as it is among a bunch of parts he was given. Let me know if the email didn't reach you.
Visits: 4.4K
I didn't get your email.
Have sent PM to you.Thanks for your response.
Regards
Posts: 3.6K,
Visits: 497.5K
Rick - a picture (I hope) of the inside of the dizzy. The shaft has no side play, but seems to turn somewhat hard. Also, there is a half tooth broken off the lower gear. Is this the bent vacuum thing you mentioned? Otherwise, it appears to be in good condition. I sent you an email with a picture to the address listed in your profile. If you want it, give me your address so I can get the shipping cots.
Visits: 4.4K
Thanks Paul
That is exactly what I need.
I have sent you a personal message.
Let me know if you don't get it.
Regards
Rick
