312 Engine with 471 heads
Posted By Drexel 16 Years Ago
Drexel
Posted 16 Years Ago
Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)
Posts: 14, Visits: 168
I have for sale a 312 engine that I removed from a vehicle and have had it sitting in my shop for several years. I do not know the history of the engine as it was not running when I purchased it. Doesn't look to bad under the valve covers but I would make the assumption it needs a rebuild. Block is ECZ-6015-C, the crank has the proper single dot on flywheel flange. The heads are 5750-471 which identifies them as the big valve intakes and low compression. The cylinders measure 3.830 so it has been bored .030. Engine has a two barrel manifold on it now but I will throw in a four barrel intake. (Holley bolt pattern) If the 471 heads are not what you are looking for then I can  switch them out for 113's or G heads. I am located in Leavenworth, Washington. Asking 700.00 OBO Thanks, Dave 509 548 6382
