Tried and failed
Posted By San Diego Ron 18 Years Ago
San Diego Ron
Posted 18 Years Ago
Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)
Posts: 117, Visits: 243
Thought I would break down and buy the $8.00 tool to quickly remove inside handles so I could replace door skins and upholstery.....NOT! After finally getting one handle off (not until I ripped panel apart) I saw that the tool had too small an opening to push spring off. After some modification with tin snips was able to get the window crank off but so far have failed to remove anything from the other doors....anyone have a better idea? the skins are reusable on the other doors (so far) and I would like to keep them that way. Thanks
P.S....why do these ten minute projects take hours and hours, is it just me?w00t
Posted 18 Years Ago
Posts: 3.6K, Visits: 497.6K
When I took of the handles on my 54, I learned that you have to hold the tool right up against the handle. I got the usual tool (harbor freight special I think) and it worked for me.
Posted 18 Years Ago
Ron: If the clips are the same as a 57, one of those cheap after market black removers should work. Push in from the long side of the handle, not from the offside. Sometimes the plastic washer inside may be previously installed incorrectly & the little flange on it may give you some trouble. Be patient! In one case I used two removers at once as they are rather thin & have a tendency to miss the clip. Hope this explanation helps. (?)
Daniel Jessup
Posted 18 Years Ago
Posts: 2.0K, Visits: 128.3K
Just my two cents - I have removed quite a few of the 55 and 56 door and window handles. The tools describe will work well as long as your retaining clip is still in good condition. I have had much success using the tool and a dental pic. These things are small and very, very strong!
Dan
Daniel Jessup
Lancaster, California
Gerry
Posted 18 Years Ago
Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)Supercharged (192 reputation)
Posts: 188, Visits: 1.9K
A body shop friend recomended a old nylon stocking just slide it back there  and pull back and forth. Pulls them clips out each time. Gerry
Lake Forest California  5th inf 77 Armor Div. VN 68/69
If you put your town and state in your signature
help might be closer than you think.
Hogfarmer
Posted 18 Years Ago
First Time Poster
First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)
Posts: 3, Visits: 14
Don't know about ford, But there is a difference between a 55 and 56 Merc.  The slot that hold the spring clip in the 55 has a sholder on it, that make use of the standard tool very hard to use.  I solved this problem by modifying the slots with a hacksaw blade and  cut down the shoulders on the 55. Tool works great and easy now.
