Value
Posted By MikeLongIsland 16 Years Ago
MikeLongIsland
Posted 16 Years Ago
Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)Supercharged (152 reputation)
Last Active: 15 Years Ago
Posts: 152, Visits: 440
There was a tri power set up on ebay, it didn't sell at 950.00, the carbs are holleys, and professionally redone, it has linkage and fuel bar, even air cleaners. I called him and he says 950.00 is his bottom price. Is it worth it?
 I'm on a Lowwwww Budget
Doug T
Posted 16 Years Ago
Last Active: 4 Months Ago
Posts: 563, Visits: 2.6K
That is an interesting intake manifold. It is not an Edelbrock which is normally considered the best ones although it looks to be better than the Offy.  It might be Fenton as they were closed between the runners as the picture shows but you usually can see the name.  The price sounds a little rich to me but with the air cleaners linkage and fuel block it is not outrageous these days.  Somebody from AIG could buy it in a heartbeat!
Doug T
Johnson Rod
Posted 16 Years Ago
Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)
Posts: 142, Visits: 838
Mike, depends on how bad you want it. I believe it is worth it if three deuces is what you want.
The only thing I don't like about the setup is the manifold, looks like a Fenton (beside the ugly fuel log). An Edlebrock would be a better choice. Rebuilt 94's go for ~ $200 with a $85 core charge (Vintage Speed, http://www.vintagespeed.com) so that's close to what your paying for the whole setup.
Now if the carbs were three Stromberg 97's I'd jump on it in a minute!!
Others will disagree because they say you can get better performance from a single four barrel (and cheaper too)... maybe... I'm not here to argue. But, if you want the LOOK of three deuces...
OK let the fireworks begin.
Johnson Rod
Southern CaliforniaBigGrin
Daniel Jessup
Posted 16 Years Ago
Last Active: 9 hours ago
Posts: 2.0K, Visits: 131.0K
Mike - that photo looks like it shows the ports being the smaller variety (early years) of head/intake matchup.
My opinion - you could do better. I would question the "professionally" redone carbs. You could get a nicer manifold, buy your carbs separately and have them redone, get your linkage for $50 from Speedway (its an OFFY part repop) and get a good fuel log from them to boot. Air cleaners are very plenteous, and there are good deals out there. You wouldn't have to spend that much ($950) to have a nice setup -- and you would be assured of what you had.
My two cents...
dan
Daniel Jessup
Lancaster, California
MikeLongIsland
Posted 16 Years Ago
Once again, thanks guys, I see what you mean about the manifold difference. I guess since i am getting married in vegas on the 9th, I really shouldn't spend the $.
Todays Progress: Nice tank, but the sender was junk, Needed the xtra legroom and my tank in the cab was shot.
yehaabill
Posted 16 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
MLI Y-Guy:      You better get "something" BEFORE you get hitched and,for
             sure, before Vegas............. Bill
Bill
Pelham,Al
MikeLongIsland
Posted 16 Years Ago
I did a 1956 f100 ! and about 2500 worth of parts for it
55Birdman
Posted 16 Years Ago
Posts: 1.0K, Visits: 4.5K
Edlebrock 573 is the best out there. #2 is Edlebrock 553. The rest are not good enough to match them. Edlebrocks are available and once in a while they are at decent prices. You can get the intake carbs linkage and fuel log for less than the $950 for this thing.  my 2c
55Birdman Smile  Hickory NC
