Posts: 3.6K,
Visits: 497.6K
Does any body know of some one who repairs overdrive solenoids or do you have one for sale that works? This is for a 55 T Bird. Hemmings no help
DANIEL TINDER
Visits: 149.7K
Paul,
If you have the time/inclination, most solenoids can be repaired quite easily (unless the coils are broken/shorted). If you like, I could send you the repair info I used to fix mine. The unpublished instructions I obtained from an old FoMoCo dealer mechanic, and the 55/56 shop manual sections are all you really need. I also built a simple test jig out of plywood, so trans. mounting not required to operate/test (it must have adequate spring resistance, or proper functioning cannot be validated). If you have a spare battery & relay, the entire system can then be bench-tested. I have found that most 6V solenoids that were tossed as defective in the past (shop manual recommendation), will still operate fine without the high current resistance due to relay corrosion.
6 VOLTS/POS. GRD. NW INDIANA
Teros292
Visits: 12.3K
Daniel, I am also interested of those repair instructions if You canve send them to me teros(at)dlc.fi . I have two broken OD solenoids. Contacts broken etc.
Tero from Nurmijarvi, Finland56 Country Sedan, 61 F-100, 61 F-600, 55 F-620, 52 Mercury
DANIEL TINDER
Visits: 149.7K
Tero (et. all),
Send email request to "dantinh62@kconline.com", and I will scan and include with reply when I get the time.
DANIEL TINDER
Visits: 149.7K
Tero/Paul,
I emailed the info twice, reversing the addressee & CC, but mail was returned undelivered both times. Let me know if either received it, or if you want it resent (alternate address?).
Posts: 3.6K,
Visits: 497.6K
DANIEL TINDER (2/14/2009) Tero/Paul,
I emailed the info twice, reversing the addressee & CC, but mail was returned undelivered both times. Let me know if either received it, or if you want it resent (alternate address?).I didn't get it. Try pts1231@aol.com or pts1231@verizon.net
Teros292
Visits: 12.3K
I didn´t get it either. Can You try again teros@dlc.fi or webmaster@fordnationals.net
ejstith
Visits: 1.0K
I just took one apart. Not much in there. I had one of the stand bolts stripped out of the base plate and I secured it back in with JB Weld. After I was done I pulled my daily driver up and hit it with the jumper cables and it clicked so I'm assuming it's gonna work. I plan on just hooking a switch to mine and bypassing the governor and just doin' in and out of OD with a switch. Hope that will work. I did that on a '57 back in the day and it worked. Check those replies to that T-89 site on "technical". A guy put a bunch of web addresses in there regarding schematics etc.
E.J. in Havana FL
DANIEL TINDER
Visits: 149.7K
Tero,
Looks like it went through on the "webmaster" address.
Teros292
Visits: 12.3K
Thanks Daniel, Now I received it.
