55 56 ford parts
Posted By carl 18 Years Ago
Glen Henderson
Posted 18 Years Ago
Posts: 1.4K, Visits: 7.5K
Don't let the core charge stop you, I have several cores, if you need one let me know.
Glen Henderson
Freedom is not Free
Letohatchee, AL
rgrove
Posted 18 Years Ago
Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)Supercharged (576 reputation)
Posts: 498, Visits: 3.5K
Any 56 convertible parts?
Ron Grove
Wauconda, IL
carl
Posted 18 Years Ago
Posts: 1.2K, Visits: 20.6K
Roger  my home e mail address is cl56vic@yahoo.com so e mail me here if it will be easer for you  there is a difference in the 2 barrel and 4 barrel kick down rods  they are the same length but have a different bend   carl
Butch Lawson
Posted 18 Years Ago
Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)
Posts: 235, Visits: 20.9K
Carl,
Do you have a flexplate for a 59-62 cruise o matic y-block?  Thanks.
Butch
Butch Lawson
Manchester,  TN
carl
Posted 18 Years Ago
Butch  How is the flex plate different from a 55 56 fordamatic.i parted out a 62 ford a couple of years ago with a 292 and it had a cruisamatic i sold the alum bellhousing but should still have flexplate.can you describe it   Carl
Butch Lawson
Posted 18 Years Ago
Carl,
The earlier Ford O Matic's had the ring gear attached to the torque converter and the flexplate was a sort of square looking device.  The later Cruise O Matic had the ring gear attached to the flex plate like all the other later model Fords.  The key is whether or not the ring gear is attached to the flex plate or the torque converter.  Hope this helps.
Butch
Butch Lawson
Manchester,  TN
carl
Posted 18 Years Ago
Butch  i have 4 flex plates but all of them are for fordamatic. sorry i cant help you   carl
Carson
Posted 18 Years Ago
Posts: 109, Visits: 1.6K
Carl , I would like to buy those # 113 edsel heads, please contact me
 rancheria@aol.com
thanks in advance , Carson
carl
Posted 18 Years Ago
i have a complete power steering setup for 55 56 ford but i dont want to just sell the pump. i have some later model pumps but you would have to change the pump bracket and also the pulley on the front of the engine.i will see if i can locate you the proper pump  carl
Butch Lawson
Posted 18 Years Ago
Carl,
Thanks for checking on the flexplate for me.  Maybe somebody else has one for sale?
Butch
Butch Lawson
Manchester,  TN
