55 56 ford parts
http://forums.y-blocksforever.com/Topic2140.aspx
By carl - 18 Years Ago
I have many good used parts for 55 56 fords for sale also some mercury. parting out a 59 edsel 4 door this car is complete with title. e mail me with your needs
By mr4speedford - 18 Years Ago
Where you loacted, and any y blocks?
i am located i circleville ohio yes i have some y blocks e mail me what you need
Roger  i am not sure if the trans linkage is the same i have both so i will check it out and let you know tomorrow.i dont have a 57 dist. i used the one i had on my 56  Carl
By MoonShadow - 18 Years Ago
Carl, I could also use a kick down rod for a 56 car with 4bbl. I think the 2 and 4 were the same but not sure. Mine has the adjustable open clevis at the carb linkage end. Chuck
Roger  i havent forgotten you i just didnt get a chance to check on the linkage today  carl
By speedpro56 - 18 Years Ago
Roger, there is a later dist on ebay # 330077641893. Check it out it may be the ticket your looking for.
Rorer do you still need the linkage for the carb.  carl
By Glen Henderson - 18 Years Ago
Check out your local NAPA store for a 57 up rebuilt dist! I bought 3 a few months ago and the price was right. If I remember they were around 50 bucks. On a different note Carquest still has rebuilt water pumps for the car engine, around $30 each. You will be surprised at what is still available if you can talk the counter person into digging around in the old parts books. The best thing you can do is get one person at the store interested in your project, let them know what you want, and give them a few days too research the old books. Another good tip is to ask them for outdated parts books as they replace them with new ones and look up the numbers yourself then call and see if the part is still available. Takes a little time to develope a relationship, but it has worked for me. Didn't mean to get on my soapbox, but maybe it will help you down the road.
NAPA has them but they are an exchange only item. If you catch a decent guy he may sell you one straight up or if you get an idiot he may not know the difference and take an old type in exchange. Try them out! Chuck
Don't let the core charge stop you, I have several cores, if you need one let me know.
By rgrove - 18 Years Ago
Any 56 convertible parts?
Roger  my home e mail address is cl56vic@yahoo.com so e mail me here if it will be easer for you  there is a difference in the 2 barrel and 4 barrel kick down rods  they are the same length but have a different bend   carl
By Butch Lawson - 18 Years Ago
Carl,
Do you have a flexplate for a 59-62 cruise o matic y-block?  Thanks.
Butch
Butch  How is the flex plate different from a 55 56 fordamatic.i parted out a 62 ford a couple of years ago with a 292 and it had a cruisamatic i sold the alum bellhousing but should still have flexplate.can you describe it   Carl
Carl,
The earlier Ford O Matic's had the ring gear attached to the torque converter and the flexplate was a sort of square looking device.  The later Cruise O Matic had the ring gear attached to the flex plate like all the other later model Fords.  The key is whether or not the ring gear is attached to the flex plate or the torque converter.  Hope this helps.
Butch
Butch  i have 4 flex plates but all of them are for fordamatic. sorry i cant help you   carl
By Carson - 18 Years Ago
Carl , I would like to buy those # 113 edsel heads, please contact me
 rancheria@aol.com
thanks in advance , Carson
i have a complete power steering setup for 55 56 ford but i dont want to just sell the pump. i have some later model pumps but you would have to change the pump bracket and also the pulley on the front of the engine.i will see if i can locate you the proper pump  carl
Carl,
Thanks for checking on the flexplate for me.  Maybe somebody else has one for sale?
Butch
I haven't been able to find my receipts for the ones that I bought and the parts house kept the boxes to return the cores in. I have them, just have to remember where the receipts are. I had a good list of part numbers going at work before I retired, but the Cyber police wiped it from my DOD computer before I could retreve it. I have found when hunting common parts at NAPA, it is better to ask them for a 63 or 64 pickup part. They seem too be more responsive.
the later model y blocks power steering pumps will work on a 56  you just have to use the brackets and pulley combination that goes with the pump you are useing  carl
chuck tryed to e mail you but your in box is full.   anyway i shipped you trans. linkage today you should get it friday carl
By Professor Longroof - 17 Years Ago
Any nice 292 valve covers (for a 1955 Country Sedan) ?
By marvh - 17 Years Ago
Do you still have the torque converter for the cruise-o-matic as I need one.
marv
By Jim Rowe - 17 Years Ago
Carl,
I need the later model Y-Block pulleys ( narrow belt ) fro the crank and the water pump. The water pump pulley should be the large Dia like found on a pick up.
Can you help me?
Jim Rowe
Elkhorn, NE 68022
402-681-1770
