Visits: 1.4K
I finally have my 55 crown running , and went for a drive around the block....ran good . ..But , i have a howling noise from the rear end when i let up on the gas.......sooooooo , i am looking for center section or pumpkin depending what part of the country you live !! Car is standard with over drive . Anybody have one foe sale let me know .....Thanks Sam.....................Central West Florida
56 victoria
Posts: 1.1K,
Visits: 58.8K
I'm just curious. why not rebuild it?
Visits: 1.4K
Alan , It would cost a lot more to rebuild than find a used replacement, and i dont know where i would find parts to rebuild,, maybe Casco or Tee-bird products ,,, but finding someone to rebuild , is almiost impossible here , and i never have tried , and dont want to , attempt that project ...Sam
56 victoria
Posts: 3.3K,
Visits: 238.8K
I tend to agree with Alan. The used one may have problems also, it's 50+ years old! What kind of howl? What about the axle bearings or pinion bearings etc. Do you belong to the CVA? Maybe they can make a recomendation on a rebuild in your area.
Last Active: 15 Years Ago
Visits: 15
SAM THERE SEVERAL DIFFERENT AXLE SPLINES USED ON THE "55". 17 IS THE MOST COMMON BUT I HAVE RAN INTO 19 AND 28 SPLINES. THEY ALL SEEM INTERCHANGEABLE IF YOU KEEP THE PUMKIN AND AXLES TOGETHER. I SHOULD HAVE A GOOD SET FOR $125. DAN
Last Active: 1 hour ago
Visits: 322.6K
Sam: Before you go to a lot of expense, try moving the input flange of the rear up and down. It may be as simple as a loose pinion nut. John in Selma, IN
Visits: 1.4K
John, thanks for the tip , will check today...............Dan thanks for the offer , where are you located and what gear ratio do you have ?....................Thanks all ......Sam ..........west central Florida
56 victoria
Visits: 1.4K
John, Its not the pinion nut . I didnt think i would be that lucky.......................Sam
56 victoria
Visits: 1.4K
Brodie , I have a good 3.22 , but would like to find , 3.60 . 3.80, 3.90 ,,,,,,,,,,Remember tis id standed with OD............Sam
56 victoria
Visits: 15
SAM IM NOT SHURE WHAT GEAR RATIOS I HAVE LEFT. I BELEIVE TWO OF THE CARS HAVE AUTOS AND THE THIRD HAS A 3SPD OVERDRIVE. DAN
