Radio Repairer
Posted By paul2748 18 Years Ago
Posted 18 Years Ago
Posts: 3.7K, Visits: 498.2K
I need to get a T & C radio (TBird) repaired. Any suggestions out there. Its not a tube issue, it has to do with some of the mechanical functions.
Thanks.
Posted 18 Years Ago
Paul 2748; If you don't get any other help with the radio, check Hemmings Motor News ads.
Posted 18 Years Ago
Brodie - thanks - I called him a week ago, left my name and telephone number - no response
Johnson Rod
Posted 18 Years Ago
Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)Supercharged (142 reputation)
Last Active: 16 Years Ago
Posts: 142, Visits: 838
Paul, you might try these guys, converted my stock nonworking '55 round faced radio to stereo http://www.radiosforoldcars.com/stereoF.htm
Johnson Rod
Southern CaliforniaBigGrin
sundance241
Posted 18 Years Ago
Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)Supercharged (203 reputation)
Posts: 202, Visits: 1.4K
Paul , I have used Tayman Electrical  in Sarasota Fla.  to convert two radios for me ,,,almost ready for another.....web-site.....taymanelectrical.com............Luck...Sam.........................................Florida west central
56 victoria
ejstith
Posted 18 Years Ago
Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)Supercharged (567 reputation)
Posts: 494, Visits: 1.0K
What do they normally charge for such a radio conversion? I would love to keep my "signal seeking" '56 radio and have it converted.
E.J. in Havana FL
dbzach64C
Posted 17 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Posts: 37, Visits: 746
Interesting thing about these old radios. Recently I took the radio out of my 56 Fairlane just to gain easier access to under the dash. While I had it out I removed the cover to see if any large insects were trapped inside. I inadvertantly scraped a short piece of wire with a fingernail and the insulation fell off. I poked at several other areas with the same result. This was a fine working radio I thought but it will not be returned to the car. Some of the other componants didn't look all that great either. I recall reading an article years ago stating that more old (re:classic) vehicles were destroyed by fire than any other cause. Anyone need a set of tubes and a vibrator for a 12v radio?
Wichita,KS
Posted 17 Years Ago
dbzach64C (1/2/2009)
Interesting thing about these old radios. Recently I took the radio out of my 56 Fairlane just to gain easier access to under the dash. While I had it out I removed the cover to see if any large insects were trapped inside. I inadvertantly scraped a short piece of wire with a fingernail and the insulation fell off. I poked at several other areas with the same result. This was a fine working radio I thought but it will not be returned to the car. Some of the other componants didn't look all that great either. I recall reading an article years ago stating that more old (re:classic) vehicles were destroyed by fire than any other cause. Anyone needa set of tubes and a vibrator for a 12v radio?
You can save the radio by stripping off the old covering on the wire and putting on shrink tubing. When I rewired my 54, and that was what I did when I wanted to save small connections of original wire.
