Going to try to make the test and tune tomorrow.
Posted By charliemccraney 18 Years Ago
ALANB
Posted 18 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 16 Years Ago
Posts: 37, Visits: 70
ONE totally forgotten feature of a thermostat , and there is a wide range in the qualitys , Even a Harrison may be made in China in todays world !!   BUT ,  A thermostat must hold the coolant back in the block long enough to absorb all the heat around the cylinders . O.k. we know this , But if it flows to rapidly , It will leave hot spots and not dissapate thru the radiator fins ... I learned this in trucking ..... ALAN B .
Fred
Posted 16 Years Ago
Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)
Posts: 8, Visits: 160
Frank's Water Pumps:  Are they high efficiency?  Where does one get one?
Smile
Fred
Posted 16 Years Ago
What is a Frank's Water Pump and where does one get one?
GREENBIRD56
Posted 16 Years Ago
Posts: 1.7K, Visits: 102.7K
I think Frank  may be out of the waterpump business these days - unless he sold that work to someone else. I believe his design had an improved impeller - Mummert may be the new proprietor?
The Thunderbird versions of the Y have a one inch spacer under the pump that plays hell with the ability of the pump impeller to be very efficient. Passenger cars don't have the spacer. If you are working on a bird - or have room for the spacer - CASCO sells a pump with additional impeller capacity added - and I believe they also offer the service of fitting stocker pumps with the upsized impeller. Their site has some interesting test data concerning the flow capacity of thermostats and pumps that is worth looking at anyway.
Concours sells a smaller diameter pulley that will speed up the stock pump relative to crank speed ($100) ......and somewhere in the past on here is a thread where I showed how to use a 289/302 single groove on a bird to crank it even faster. The t-birds not only suffer from the pump spacer - but they also have a bit smaller radiator than the passenger cars.
link http://www.y-blocksforever.com/forums/Topic35079-3-1.aspx?Highlight=pump+bypass
BrianL
Posted 16 Years Ago
Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)Turbocharged (70 reputation)
Posts: 67, Visits: 1.2K
I have one of the improved impeller water pumps that Steve mentions above. What Casco did was to use some galvanized sheet metal to make larger impellers & rivet it on. I had previously tried a water pump cavity block off plate & it had the effect of increasing my temps (not what I was looking for). The test data that Steve mentions on the Casco site is a good read & also confirms my finding of the backer plate.
I also have the smaller pulley mentioned.
Brian - 56 T-Bird
Woodinville WA
webconst
Posted 16 Years Ago
Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)
Posts: 48, Visits: 5.8K
I had 2 T-Bird radiator cores made by this company in 1976 (Mancum-Manufacturing Co., Atlanta & Houston).  At that time they had to make the dies to stamp the 4 staggered rows for 1/2 inch tubes in headers and fins. All copper and brass with 12 fins per inch.  Installed one of them in my '57 T-Bird.  Engine 30 over, heads cut 30, 5 blade clutch fan and 180 degree thermostat.  My wife and I drove to T-Bird convention in Dallas in June, 1978; air conditioner ran all the way with temps up to 107 degrees. (15 day trip) We experienced no overheating problems.  I credit this to the quality and design of the radiator.  I do not know if this company is still in business, maybe interested members could research it.  Charlie, Central Fl.
