Holley Knock Offs on Amazon
Posted By oldcarmark Last Week
Posted Last Week
Posts: 3.8K, Visits: 33.4K
There are new Listings on Amazon for "Replacement Holley Carbs" Made where else but China. According to reviews and actual teardown Videos online they are absolute Garbage. Not even close to Holley quality and basically unusable. I am surprised they are even listing them for Sale on Amazon. Buyer beware.
Posted Last Week
Last Active: 4 days ago
Posts: 4.6K, Visits: 39.5K
Amazon literally does not watch its sellers.
Posted Last Week
Listings do not even show a Seller Contact Information.
DANIEL TINDER
Posted Last Week
Posts: 1.8K, Visits: 154.7K
I think only items both ‘sold AND shipped’ by Amazon get any serious quality inspection. Lots of counterfeit junk offered online these days. Anything considerably less expensive is suspect, especially.
6 VOLTS/POS. GRD. NW INDIANA
Posted Last Week
Posts: 7.6K, Visits: 206.1K
I recently had an opportunity to dyno test a pair of those ‘inexpensive’ carburetors with both Tim McMaster and Joe Craine helping with the testing.  While the 650 version did run okay with some tuning, the 850 version was a dismal failure.  The 850 idled fine but refused take fuel with any throttle opening over idle.  A couple of hours was spent in trying to determine exactly what was the problem with the carburetor at which point the carburetor was simply put to the side as not workable.
With Tim leaving the 850 carburetor here with me, I later reinstalled it on the 312 dyno mule for further testing.  What I eventually found was that the discharge nozzles were simply placed too high in the venturis thereby not being able to draw fuel when the low pressure at the venturis was present.  I actually took a drift punch and forced the nozzles into a lower position which helped but did not fix the carburetor.  I had an older Holley List 4781 (850 cfm) center section sitting loose that I simply substituted for one in the new carburetor and that was an instant fix.  I did have to change the idle bleed restrictions in that center section but that’s not unusual when swapping out metering blocks and other parts.
If there’s any consolation in the price, the remaining parts like the fuel bowls, throttle plate assembly, and metering blocks are well worth the money as buying them individually would have been much more expensive.  Still a disappointment though in that people are buying that carburetor to simply bolt on and run; it simply does not do that.
Here’s a link to a video showing exactly both of these carburetors being tested at another dyno facility mirroring the same results.
http://facebook.com/reel/1102228942425856
http://forums.y-blocksforever.com/uploads/images/7980a398-f585-4cb4-90e0-64aa.jpg
http://forums.y-blocksforever.com/uploads/images/c2ade6b5-b3c8-408e-9c5b-6b26.jpg
Posted Last Week
Holley carburetors are "primarily engineered and assembled in the United States", although some components are made elsewhere, including China.
Posted Last Week
There are Videos on Google outlining other Issues with these Carbs. Obviously whatever Chinaman designed these had no idea what He was doing. Some Automotive Products are best left to experts for design.
lazylnm
Posted Last Week
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 56, Visits: 699
Speaking of offshore produced carbs, does anyone have any experience with the Holley 94 clones on Ebay?
2 Barrel Carburetor Carb for Ford Truck Flathead V8 239-272 1939-1959 TR55222 | eBay
H.A.M.B. members say they work "great".  Other reviews cite dismal manufacturing tolerances.  Any real experience with these?
Litshoot
Posted Last Week
Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)Supercharged (231 reputation)
Posts: 78, Visits: 751
Ted (11/10/2026)
Do you think replaceing the boosters would have fixed the holey carb, or it was casting/machineing issue. good to know its agood option for some parts for a holley
Posted Last Week
Last Active: 25 minutes ago
Posts: 2.0K, Visits: 306.7K
"Obviously whatever Chinaman designed these had no idea what He was doing"
Somebody had a good idea as people keep buying the junk ...
They look and go good with the INTERSTATE BATTERY, STANT PRESSURE CAP (w/ pressure release lever) and OFF-SHORE SLOPPY-COPY EDEL ACL w/ the ever popular plastic fuel filter plumbed in with rubber fuel hose and too large and over tightened worm gear hose clamps.
