cos
Visits: 120.0K
Hello members. My be buying trouble but. Have a stock 292 that previous owner had rebuild but never started. I disassembled to check things and put a OEM spec blower cam in. Timing is Intake open 6 BTDC close 38 ABDC Exhaust open 51 BBDC close -5 ATDC at .050. Lobe separation 112. overlap 1 at .050. Vacuum seem low 12" HG. Idle screws adjustment responds, don't think i there is a leak. Carb PVC plugged idles at 800.. Thinks this is normal?
Posts: 1.4K,
Visits: 2.0K
What is the camshaft duration @ .050?
cos
Visits: 120.0K
Thanks 224/226
Posts: 1.4K,
Visits: 2.0K
With a 112 LSA and minimal overlap, I'm thinking you should have at least 14" of vacuum. Is there advance ground into the cam? Did you advance it 2-4 degrees? Advancing it 2-4 degrees should help.
Is the camshaft new or a regrind? If you know the brand and part number, somebody might be using that cam and can tell you how much vacuum you should have. Hopefully, you don't have power brakes.
Last Active: 25 minutes ago
Posts: 2.0K,
Visits: 306.7K
"Vacuum seem low 12" HG."
Does the gauge needle stay steady?
Visits: 206.1K
The opening and closing specs you previously listed are obviously the 0.050” specs as they calculate to be 224° and 226°. It would be interesting to know the advertised opening and closing numbers as that would give the actual duration of the camshaft. Those numbers are typically at 0.020” lobe lift or at tappet lash values. The advertised duration for the hi-lift blower camshaft is 290°, 234° @ 0.050”, and was ground on 110° lobe centers. I’m curious as to what markings were on the camshaft you used as that could help to further identify it. Did you degree in the camshaft when installing it or just installed the camshaft using the timing chain pin count? Not degreeing in the cam can make a significant difference in where the camshaft is actually residing simply due to the manufacturing variances that can occur. A cranking compression check can possibly give some more information on where the camshaft is installed as a low reading will point to a retarded camshaft while an abnormally high reading will point to an advanced camshaft. Another quick check would be to have both the intake and exhaust valves level for the #1 or #6 cylinders at the overlap cycle (exhaust valve closing, intake valve opening) and then check the damper for the amount of advance or retard that present. This relies on the damper being accurate to the timing pointer for this method to work.
Posts: 1.4K,
Visits: 2.0K
cos (11/9/2026)
Hello members. My be buying trouble but. Have a stock 292 that previous owner had rebuild but never started. I disassembled to check things and put a OEM spec blower cam in. Timing is Intake open 6 BTDC close 38 ABDC Exhaust open 51 BBDC close -5 ATDC at .050. Lobe separation 112. overlap 1 at .050. Vacuum seem low 12" HG. Idle screws adjustment responds, don't think i there is a leak. Carb PVC plugged idles at 800.. Thinks this is normal? Manual or automatic transmission? 800 rpm idle in neutral or in gear?
cos
Visits: 120.0K
Thanks for replies. Cam was from Oregon cam grinding part #2063. Ken told me it was copied from a OEM EDB S/C cam that he has. The advertised duration at .002 334/343. at .020 1s 256/259. cam lobe lift .293/.295. from cam card. No advance in cam and used stock timing chain set at 12 pins. I checked compression after cam broke in and believe 160 psi. plus or minus few lbs., vacuum is steady at idle just low..
Posts: 2.0K,
Visits: 306.7K
Here are some notes I saved offered by Ted Eaton - " Most of the 1958 and newer FORD OEM Y camshafts are ground on113° lobe centers. While the ground lobe centerline does not change when installing the camshaft, it can be advanced or retarded. When installing those camshafts, I will install with 4-6° advance which equates to 107-109° intake lobe centerlines. That in turn makes the exhaust lobe centerlines 117-119°. No matter how you install that particular camshaft, it will always add up to 226° between the intake and exhaust lobe centerlines. The actual lobe centerlines on a camshaft can be verified during the cam degree in process.
If simply installing the camshaft so the sprocket marks are 12 pins apart and not actually degreeing in the camshaft, the actual cam timing could be anywhere. Have seen 18° off in both directions with the timing marks being where they need to be. Hence the need to degree in the camshaft. A compression test can sometimes point you in the direction of too much advance or too much retard on a camshaft. One tooth off when installing the chain is a common error and most engines will still start and run like that."
Posts: 1.4K,
Visits: 2.0K
cos (11/11/2026)
Thanks for replies. Cam was from Oregon cam grinding part #2063. Ken told me it was copied from a OEM EDB S/C cam that he has. The advertised duration at .002 334/343. at .020 1s 256/259. cam lobe lift .293/.295. from cam card. No advance in cam and used stock timing chain set at 12 pins. I checked compression after cam broke in and believe 160 psi. plus or minus few lbs., vacuum is steady at idle just low.. I didn't find grind # 2063 on Oregon Cams' Mechanical Camshaft Specifications Sheet.
