Visits: 751
Hi again, here to beat a dead horse. Im looking to get a rowdy sounding cam, but its been difficult to really hear whats out there. Building a 292, possibly a stroker in future, going in 3k ranchercho with 5 speed.
Im curious about the organ 977-280 290 on a 108 1313- 272 282 on 108 Both have higher dcr(ivc closes earlier) and more overlap at .050, advertised is similar or less. Is this line of thinking flawed, or worth moving forward to ask oregon Seth
Last Active: 25 minutes ago
Posts: 2.0K,
Visits: 306.7K
... whew ... I would talk directly withe OREGON CAM and/or ISKY TECH as to what you want and how to go about it.
CAM TECH has changed a lot since 1957.
Most responses here are HP.
And don't forget the valve-train.
And if/when you get a recommendation(s), share it here.
Visits: 206.1K
The factory supercharger cam has a reasonably rumpy idle. The basic specs for that particular camshaft are 290° advertised, 234° @ 0.050”, ground on 110° lobe centers, and has a lobe lift of 0.290”. I’ve always considered this camshaft to be worth about 15HP over the factory 1957 camshafts when installed in basically stock engines. Isky can reproduce this camshaft on new blanks. As a general rule, reducing the lobe centerline increases the engine rumpiness or lope at idle at the expense of reduced manifold vacuum at idle. That reduction in manifold vacuum reduces the signal to the carburetor which will require some extra carb tuning in which to compensate. For normally aspirated engines, using 110°/108° or even smaller lobe centers will give that lopey idle versus using a camshaft that has a wider lobe centerline. For any kind of boosted application, it’s always best to use a wider lobe centerline to prevent the boost from escaping into the exhaust during the valve overlap cycle. There is a balance between the static and dynamic compression ratios that must be maintained in order to have decent driving characteristics. Not having sufficient static compression ratio when using a camshaft with increased duration will have the dynamic compression ratio too low to make adequate torque and be a good driver. Here’s the link to an earlier post about camshaft selection. http://forums.y-blocksforever.com/FindPost170419.aspx
Visits: 751
Ted (11/4/2026)
The factory supercharger cam has a reasonably rumpy idle. The basic specs for that particular camshaft are 290° advertised, 234° @ 0.050”, ground on 110° lobe centers, and has a lobe lift of 0.290”. I’ve always considered this camshaft to be worth about 15HP over the factory 1957 camshafts when installed in basically stock engines. Isky can reproduce this camshaft on new blanks. As a general rule, reducing the lobe centerline increases the engine rumpiness or lope at idle at the expense of reduced manifold vacuum at idle. That reduction in manifold vacuum reduces the signal to the carburetor which will require some extra carb tuning in which to compensate. For normally aspirated engines, using 110°/108° or even smaller lobe centers will give that lopey idle versus using a camshaft that has a wider lobe centerline. For any kind of boosted application, it’s always best to use a wider lobe centerline to prevent the boost from escaping into the exhaust during the valve overlap cycle. There is a balance between the static and dynamic compression ratios that must be maintained in order to have decent driving characteristics. Not having sufficient static compression ratio when using a camshaft with increased duration will have the dynamic compression ratio too low to make adequate torque and be a good driver. Here’s the link to an earlier post about camshaft selection. http://forums.y-blocksforever.com/FindPost170419.aspx Ted, thanks as always. i know theres a lot of information on top numbers for compression but is there minimums to be aware of? im probably running 87 octane since its flat, not a lot of load and static compression isnt going to be very high until i rebuild the bottom end. ive only be able to find that 87 octane iron head dcr of 7.2-7.5 is the high end of safe and 91 octane 8.5 is the top. is there a general bottom number to be aware of? Seth
Visits: 206.1K
Litshoot (11/11/2026) I'm probably running 87 octane since its flat, not a lot of load and static compression is not going to be very high until I rebuild the bottom end. I've only be able to find that 87 octane iron head DCR of 7.2-7.5 is the high end of safe and 91 octane 8.5 is the topIf the engine has a carburetor, premium grade gasoline is always the better choice even if the engine has a compression ratio that’s suited for the lower octane grades. It’s not so much about the octane rating as it’s more about the amount of ethanol in the gasoline. Premium grades, at least in my part of the country, typically only has 3-5% ethanol in it versus the full 10% in the lower octane grades of gasoline. The corrosive nature of the ethanol is enough reason not to use any more ethanol than you have to but the fuel mileage also decreases with the increase in ethanol content. Also keep in mind that the shelf life of ethanol laden fuel also decreases as the ethanol amount increases. And for the older carburetors that were calibrated for straight gasoline, the addition of ethanol tends to lean them out thus requiring adjustments to compensate for that.Litshoot (11/11/2026) Ted, Thanks as always. I know there's a lot of information on top numbers for compression but are there minimums to be aware of? I've only be able to find that 87 octane iron head DCR of 7.2-7.5 is the high end of safe and 91 octane 8.5 is the top. Is there a general bottom number to be aware of? SethA stock 1957 312 had a Dynamic Compression Ratio (DCR) in the ~8.0:1 range with the factory camshaft (246° adv duration on 113° lobe centers and 6° advance). That same camshaft in the 1957 292 engine had a DCR of 7.5:1 while the 1957 272 had a DCR of 7.1:1. Installing the Isky E-4 in the aforementioned 272 with its 260° advertised duration and ground on 108° lobe centers at the same 6° advance has the DCR at 7.0:1 which explains why that camshaft is a favorite for many Y builds; a great increase in performance with a nice exhaust rumble while not sacrificing much in the way of DCR and with nice driving manners using both near stock or out of the box carburetors. While I do try to target for an 8.0:1 DCR in many of the Y builds, 8.2:1 DCR would appear to be the maximum safe target for 91-93 octane gasoline. I have had issues at 8.6:1 DCR. While I do not go out of my way to build engines with an intentionally low DCR, gut feels says 6.5:1 DCR should be the absolute lower limit for the DCR in any street driver. Here are some general guidelines. A smaller advertised intake duration camshaft will raise the DCR while those with increased degrees of intake opening will have lower DCR’s. A reduced lobe centerline on the camshaft will raise the DCR while an increased lobe centerline will reduce the DCR. Advancing the camshaft will increase the DCR while retarding the camshaft will reduce it. Running with an increased intake valve lash will raise the DCR while tightening up the lash will make it go the opposite way. Mixing any of these in various combinations will alter the DCR. Other comments always welcome.
