312 Rear Main Seal
Posted By Cliff Last Month
Cliff
Posted Last Month
Posts: 908, Visits: 14.0K
Take a look   https://www.ebay.com/itm/365890802119?fits=Make%3AFord&_skw=312+ford&itmmeta=01M5ZFP74FBSVYC2T9V6HY9F0M&hash=item5530ca91c7:g:WpIAAeSwMSRo2gNo&itmprp=enc%3AAQALAAAA8CHNgUiiE%2FjQhlDTaMiAde91nKGhoelhgLCbTzDZdiHhZMQ2KsEzcH4ZmhGm8cvqOcHC%2FCSEWIdQKzyKZeXW%2B2q%2FO2Wp0O9uv3AbD6r%2FlVPk6%2BHjTv6cnaPqWYnYNcMro%2F8HtVuo9a7Tj0hmUeA3MbrDceiC%2FTtC%2FRukF1fD7JruQMTHD73s9WGMSNtH8H88vu%2BPIXDvXUtKOmJ6llNnQEmHo4v2D9Zgv6TygeB6BcJu6ssXRvohiiNo3cpw%2BQOyKp0%2FWIuyUjG8PrvXr5gERPORdaFqbvCc43%2F7Ksg9KZga6kJs7in4Q0DreTM%2BvKWVHQ%3D%3D%7Ctkp%3ABk9SR7by2O-vaA
Posted Last Month
Posts: 3.7K, Visits: 498.3K
More crap from China ?
Posted Last Week
Posts: 3.8K, Visits: 33.4K
Geez. Do they have them for 292? I would rush to buy One if they do. Why buy from Best if these are much cheaper?  NOT Serious.
Posted Last Week
Posts: 7.6K, Visits: 206.1K
If someone would like to donate one of these seals to the cause, the 312 dyno mule has started leaking at its rear main seal and I will have to eventually address that at some point in the near future.  It’s not a bad leak at this time but I expect it to get worse as time goes on.  As the dyno mule is reasonably easy to work on as not being in a car, this would be an opportunity to just install one of those seals, assuming it passes a visual inspection, and just see if works.
That engine with the Best Gasket neoprene seal has ~11K road miles and is fast approaching the 1200 dyno pull mark.  The DTS dyno is currently receiving some maintenance work on the water valves and as soon as it’s back up and running, the 312 dyno mule is already set up to do some carburetor testing.
Posted 9 days ago
Ted in your experience are most rear Seal Leaks the actual Seal or more often the side Seals? My recent rebuild is leaking from rear Seal. Instead of using the supplied Best Side Seals I used the "Permatex Right Stuff"  to fill the side Cavities. It appeared to fill the side area on both Sides completely but I will have to redo it On John Mummert's Video regarding Rear Main Seal installation He admits once in awhile He has to redo it due to Leaking. I don't feel so bad now having to redo mine.
Posted 8 days ago
oldcarmark (11/17/2026)
Ted in your experience are most rear Seal Leaks the actual Seal or more often the side Seals? My recent rebuild is leaking from rear Seal. Instead of using the supplied Best Side Seals I used the "Permatex Right Stuff" to fill the side Cavities. It appeared to fill the side area on both Sides completely but I will have to redo it. On John Mummert's Video regarding Rear Main Seal installation, He admits once in awhile He has to redo it due to Leaking. I don't feel so bad now having to redo mine.
For the neoprene rear seals, I find significantly more instances of leaking side seals versus what you see with the rear crankshaft seals.  This is not just with the Ford Y-Block engines, but also the FE and M-E-L engines.  When there are issues with the rear main seals, those usually happen when those seals are not installed with an offset at the parting line and/or installing one or both of the seals with the lip facing the outside of the engine rather than to the inside.  It’s so easy to install the rear seals with the seal retainer half of the seal with the lip facing the wrong direction so always double check yourself when installing those seals.  Over the course of the last fifty plus years, I have managed to install the lower half of the seal facing the wrong direction in two engines.  One of those I caught right away on the test stand but the other was only caught after installing the engine in the vehicle.  Forty plus years between instances but I do tend to remember things like that.
Posted 8 days ago
Thanks Ted. It's reassuring to know even the experts make a Mistake once in awhile.LOL
