Valve cover gaskets
Posted By 58F600 Last Month
58F600
Posted Last Month
Posts: 111, Visits: 471
It's 2026 who makes the best valve cover gaskets available. I seen real gaskets makes them, but if they're like the pan gasket I'm afraid they'll squidge out. Anyone try them. I did the fel pros last time and they only lasted a couple years. This truck gets driven hard and often.
Posted Last Month
58F600 (10/15/2026)
I bought the Tennessee Real Gaskets vc gaskets, but I haven't installed them yet. Dan Jessup (hotrodreverend.com) probably has the most experience using them.
FORD DEARBORN
Posted Last Month
Posts: 852, Visits: 113.5K
The only gasket, in my particular case, that would seal 100% and lasted well over 10 years are the 1/4" neoprene gaskets sold by John Mummert. I have a slightly warped valve cover so my problem is unique. As mentioned above Dan Jessup had good success with the silicone gaskets and has an excellent video.
Posted Last Month
Last Active: 25 minutes ago
Posts: 2.0K, Visits: 306.7K
58F600                                      Posted Yesterday
What CCV SYSTEM is used on the engine?
https://www.youtube.com/watch?v=Iwq1i_C3fWY
58F600
Posted Last Month
Yeah I think my valve cover might have a little warp in it. I'll check it out when I pull it off again. That's what I was looking for. Something a little stiffer than the 100% silicone one. Maybe I'll get both and give them both a try
58F600
Posted Last Month
It has the PCV conversion back in the rear. That runs to a catch can and has a checked valve in it between the catch can and the base of the throttle body. No boost goes into the crankcase.
Posted Last Month
Posts: 3.7K, Visits: 498.3K
I use plain cork gaskets that I have laying around and I don't have any leaks.
Posted Last Month
"It has the PCV conversion back in the rear. That runs to a catch can and has a checked valve in it between the catch can and the base of the throttle body. No boost goes into the crankcase."
You have an OIL SEPARATOR plumbed in? How much does it collect between services?
Do you have a photo of the install?
58F600
Posted Last Month
Pcv system video.
https://youtube.com/shorts/7SK7ATh-zOI?is=_p3eZFUCH7XY1BUL
Posted 2 Weeks Ago
How is the crankcase ventilated under boost (piston ring blow-by)?
Brand name on the oil separator?
