White spark plugs, too lean????? 1955 Tbird Holley 4000
Posted By RossL 3 Months Ago
RossL
Posted 3 Months Ago
Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)Supercharged (431 reputation)
Last Active: 12 hours ago
Posts: 160, Visits: 7.3K
DANIEL TINDER (6/23/2026)
Are AL #45s still available? I thought I read somewhere a while back that they were discontinued.
Autozone has them in stock.  I read Autolite's parent company is bankrupt.
Posted 3 Months Ago
Posts: 2.0K, Visits: 306.6K
- AUTO-LITE - BUT WON'T -
- QUOTE FROM TED EATON -
SPARK PLUGS – AUTO-LITE
I am slowly moving away from Auto lite to NGK on the shop-built engines due to having a better heat range selection with NGK’s as well as having some brand new Auto-lites not firing from the git go. The Auto-lites have been coming from both Mexico and China, but it is the China made Auto lite spark plugs that I have had trouble with. It seems to be potluck at the parts store on which country of origin the Auto-lite spark plugs are from. I now do a mandatory ohm check on the new spark plugs before installing them.
TED EATON - http://forums.y-blocksforever.com/Topic165607-3.aspx
RossL
Posted 3 Months Ago
KULTULZ (6/23/2026)
Can you find the NGK's in different heat ranges?   I was looking for WR6 and could not find them
Posted 3 Months Ago
I was going to buy Autolite plugs from Walmart, but they raised the price. I ended up buying NGK plugs from RockAuto (best price at the time). My NGK plugs are V-Power Resistor Type plugs, WR5 2438.
FORD DEARBORN
Posted 3 Months Ago
Posts: 841, Visits: 113.5K
Just installed a set of NGK WR5's in my 312 and so far very satisfied. Resistance reading 10% within 5000 ohms - that's very good.
FORD DEARBORN
Posted 3 Months Ago
http://forums.y-blocksforever.com/uploads/images/a31a78c7-3a4a-4c92-847e-d7f.jpegMaybe this will help.
Posted 3 Months Ago
