Prototype Silcone Gaskets from Real Gaskets Tennessee
Posted By Daniel Jessup 8 Months Ago
Daniel Jessup
Posted 6 Months Ago
Last Active: 10 hours ago
Posts: 2.0K, Visits: 131.2K
DANIEL TINDER (5/19/2026)
I have some concern re: silicone gaskets (though I DO have their oil pan gasket, which I plan to use eventually).
I recently removed my cast/T-Bird valve covers to finally adjust valve clearance after many years. They have older neoprene gaskets attached with RTV, and are sealed to the heads each time with bearing grease..  The covers have been removed several times over a span of 20+ years, and the gaskets still look like new and have never leaked. They are impressed with the raised part of the iron heads where they seal.
  Since the silicone gaskets must be installed dry, unless the parts they seal have a recessed trough that captures the gasket, frequent disassembly could be problematic, as they likely cannot be permanently attached with RTV (?). I’m also worried they thus may squeeze out of place when torqued (?).
Please watch my video of installation and the test run I have completed.
https://youtu.be/W3hqqv8s6h4?si=V2hJaGZw5kapOKo_
It is obvious that using RTV silicone is not a problem.
Daniel Jessup
Red Lion, Pennsylvania
DANIEL TINDER
Posted 6 Months Ago
Last Active: 7 hours ago
Posts: 1.8K, Visits: 154.7K
Great. I assumed there might be an adhesion problem with RTV, since the instructions were to install dry. Glad to see that’s not the case.
6 VOLTS/POS. GRD. NW INDIANA
Posted 6 Months Ago
Daniel Jessup (5/20/2026)
Just enough RTV to hold the gaskets in place during installation?
FORD DEARBORN
Posted 4 Months Ago
Last Active: 2 Weeks Ago
Posts: 852, Visits: 113.5K
I would like to share my recent experience with the silicone valve cover gaskets from Real Gasket Tennessee: Since about 2013 I've been running neoprene valve cover gaskets purchased from Mummert Y-block with no problems until very recently. The left cover rear corner just above #4 exhaust port started weeping. Pulled the valve cover to discover that particular corner of the gasket started to break down becoming a bit spongy as can happed with neoprene when exposed to oils.  The gasket served well for all these years, no big deal so I purchased the silicone gaskets from RGT.  The silicone gasket would not seal that back corner of the valve cover and as I discovered, the cover was pranged enough to where there was very little clamping force at that corner. It was probably due to folks from the past pounding in screwdrivers and the likes to break the cover loose. The cover looked fine to the eye but with a straight edge laid along the gasket surface it was obvious that corner was raised. I took the path of least work and ordered another pair of neoprene gaskets from John Mummert and problem solved. Daniel Jessup's video proves the silicone gaskets are an excellent product and will probably outlast other gaskets. This  is just MY story, your results may be different. The neoprene valve cover gasket is 1/4" thick and very payable, allowing it to conform to my "bent" valve cover. I am a fan of silicone gaskets and will add that the silicone oil pan gasket I installed has worked very well even on my used and abused oil pan.
