Prototype Silcone Gaskets from Real Gaskets Tennessee
Posted By Daniel Jessup 8 Months Ago
FORD DEARBORN
Posted 7 Months Ago
Last Active: 2 Weeks Ago
Posts: 852, Visits: 113.5K
Thanks for all the effort - we now have a couple more items updated to modern world technology that was long overdue....
Robs36Ford
Posted 7 Months Ago
Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)Supercharged (260 reputation)
Last Active: 8 hours ago
Posts: 95, Visits: 335.9K
55Blacktie
They do have it, they call it "PUSHROD COVER GASKET-FORD Y BLOCK"
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes.
1968 Merc Cyclone FB GT 390, Getting a better front clip!
1977 Ford F-250 Supercab RWD Explorer Long box.
1976 Chev Camaro RS LT
Future rebuild : 1949 Ford F-1
Daniel Jessup
Posted 7 Months Ago
Last Active: 10 hours ago
Posts: 2.0K, Visits: 131.2K
Here is the link to the push rod cover/valley pan gasket: https://realgaskets.com/product/pushrod-cover-gasket-ford-y-block/
Daniel Jessup
Red Lion, Pennsylvania
Deyomatic
Posted 6 Months Ago
Posts: 309, Visits: 2.6K
Stupid question...The description makes it sound like only one comes in the package.  Is this for both sides?
Posted 6 Months Ago
Deyomatic (5/2/2026)
The valve-cover gaskets are sold in pairs for $47. The valley cover is now available as well for $32.50.
Deyomatic
Posted 6 Months Ago
Thanks 55 I'm a bonehead...I'm not used to hearing these called pushrod cover so I would have ordered the wrong thing.
Posted 6 Months Ago
I ordered the valve cover & "pushrod cover gaskets, along with a C4 pan gasket this morning. I already had the oil-pan gasket.
FORD DEARBORN
Posted 6 Months Ago
Are your valve covers aluminum or steel?
Posted 6 Months Ago
FORD DEARBORN (5/17/2026)
Tbird cast aluminum.
DANIEL TINDER
Posted 6 Months Ago
Last Active: 7 hours ago
Posts: 1.8K, Visits: 154.7K
I have some concern re: silicone gaskets (though I DO have their oil pan gasket, which I plan to use eventually).
I recently removed my cast/T-Bird valve covers to finally adjust valve clearance after many years. They have older neoprene gaskets attached with RTV, and are sealed to the heads each time with bearing grease..  The covers have been removed several times over a span of 20+ years, and the gaskets still look like new and have never leaked. They are impressed with the raised part of the iron heads where they seal.
  Since the silicone gaskets must be installed dry, unless the parts they seal have a recessed trough that captures the gasket, frequent disassembly could be problematic, as they likely cannot be permanently attached with RTV (?). I’m also worried they thus may squeeze out of place when torqued (?).
6 VOLTS/POS. GRD. NW INDIANA
