oiling problem fix
Posted By montana ford man Last Month
montana ford man
Posted Last Month
Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)Supercharged (407 reputation)
Last Active: 2 Weeks Ago
Posts: 167, Visits: 23.9K
thought i would update on my oiling problem a while back,i was getting very little oil to the rockers so i did what was suggested and forced grease through the oil passages  there wasnt much restriction .I thought a new oil pump would be a good idea,problem solved!  plenty of oil pressure and oil to the rockers.im not an expert on oil pumps but i cant figure out what is wrong with the old pump.This is on my 55 crown victoria  she starts and runs pretty good on 6volts even when it got down in the low teens so im pretty happy.thanks for the help!
Posted Last Month
Last Active: 5 hours ago
Posts: 7.5K, Visits: 205.9K
What pump did you remove from the engine?  Spur-gear or gerotor?  Is it possible that the original pump was pulling in air at the inlet fitting and just replacing the pump inadvertently fixed the oil flow issue?  What pump went back on the engine?  New, rebuilt, spur-gear, gerotor, etc.?
montana ford man
Posted Last Month
The old one was a gear and the new one is a melting I bought at oriellys
montana ford man
Posted Last Month
Melling
RossL
Posted Last Month
Last Active: 4 days ago
Posts: 117, Visits: 7.2K
Where did you but it?  Was it a bolt in or did it need machining?
Posted Last Month
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Posts: 1.3K, Visits: 1.9K
Melling M-42 spur-gear pump is $145.99 at Summit Racing. Shipping is free if you spend over $109. If you have a gearotor pump, Melling's K-56 rebuild kit is $47.99.
montana ford man
Posted Last Month
As I recall,I bought the melling m-42 pump  it was about $140 with free shipping over night so I was very pleased.
