Visits: 32.7K
I am rebuilding my 292. I understand it is a good Idea to run a Tap through all the Head Bolt Threads in Block to make sure Torque is correct. I have a Set of regular Taps. What is the difference in a "Bottoming Tap". Also when assembling do the Head Bolts go in Dry or Light Oil on Threads? Thanks!..
Visits: 497.9K
A regular tap has a sort of a pointy end to it. The bottoming tap has an end that is more squared off so the full cutting parts can go in deeper. A bottoming tap is usually used in a blind hole. In the case of threads that take a lot of torque like head bolts, it is better to use a thread chaser rather than a regular or bottom tap. Use of a tap may cut the metal lessening the strength of the threads, while the thread chaser just cleans.
Visits: 32.7K
I haven't heard that Term "Thread Chaser" before. Another Type of Tap? Bolts for Heads should be assembled Dry? Thanks
Posts: 1.3K,
Visits: 1.9K
Paul is correct. A "Thread Chaser" is like a tap but more precise to prevent damage to existing threads. They are also more expensive, but a $30 thread chaser is cheap insurance.
Visits: 32.7K
OK Got it. Thanks!
Last Active: 5 hours ago
Visits: 335.4K
Here is a good video of thread chaser: https://www.youtube.com/watch?v=U7_9RSV7jTI&t=47s
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes. 1968 Merc Cyclone FB GT 390, Getting a better front clip! 1977 Ford F-250 Supercab RWD Explorer Long box. 1976 Chev Camaro RS LT Future rebuild : 1949 Ford F-1
Visits: 5.4K
Always use a light oil on the threads for a more consistent and accurate torque.
