Exhaust manifold bolts coming loose
Posted By RossL 2 Months Ago
RossL
Posted 2 Months Ago
Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)Supercharged (287 reputation)
Posts: 108, Visits: 7.2K
I installed new exhaust manifold gaskets about 4 months ago (1955 Tbird 292).   I tightened them down and after running it a couple of times I tightened them again.   I checked them this weekend and a couple were not tight, they needed 1/8 of a turn.   I heard if you tighten them too much the manifold could crack.
I obviously have to go a little tighter, is this common?   I thought I read someone else had a similar issue.
Threaded View
Threaded View
Forum Post Exhaust manifold bolts coming loose By RossL ( 2 Months Ago )
Forum Post I'm no expert, but the 292 in my hot rod does the same thing. Every... By Deyomatic ( 2 Months Ago )
Forum Post One of the speed shop parts catalogs may still offer ‘locking’... By DANIEL TINDER ( 2 Months Ago )
Forum Post Are you using lock washers ? The star lock washers may work better... By paul2748 ( 2 Months Ago )
Forum Post [quote][b]paul2748 (1/3/2026)[/b][hr] Are you using lock washers ?... By RossL ( 2 Months Ago )
Forum Post Maybe the Manifolds are NOT flat. They can be re-surfaced by any... By oldcarmark ( Last Month )
Forum Post They came from the factory metal to metal and there was a reason for... By KULTULZ ( Last Month )
Forum Post [quote][b]DANIEL TINDER (1/2/2026)[/b][hr] One of the speed shop... By DANIEL TINDER ( Last Month )
Forum Post [quote][b]DANIEL TINDER (2/26/2026)[/b][hr] Again, worked for me,... By RossL ( Last Month )
Forum Post [quote][b]RossL (2/28/2026)[/b][hr] [quote][b]DANIEL TINDER... By DANIEL TINDER ( Last Month )
Forum Post You don't want to use a composition gasket on an exhaust manifold as... By KULTULZ ( 2 Months Ago )
Forum Post [quote][b]KULTULZ (1/3/2026)[/b][hr] You don't want to use a... By DANIEL TINDER ( 2 Months Ago )
Forum Post No problem with using the composition gaskets. I have used them on... By paul2748 ( 2 Months Ago )
Forum Post The only y block I have seen that the exhaust manifolds didn't leak as... By Big Tim ( Last Month )
Forum Post The exhaust manifolds on my 55 Tbird weren't leaking when I started... By 55blacktie ( Last Month )
Forum Post I have been using Nord Lock washers on the headers on my FE powered... By Ted ( Last Month )
Forum Post [quote][b]Ted (2/10/2026)[/b][hr] I have been using Nord Lock... By RossL ( Last Month )
Forum Post By design, there are larger holes in the exhaust manifolds to allow... By Ted ( Last Month )
Forum Post - WHEN ALL ELSE FAILS - By KULTULZ ( Last Month )
Forum Post I am going to try Summit Racing™ Split Lock Bolt Kits SUM-910120.... By RossL ( Last Month )
