T-Bird Crank Damper
Posted By Dad's Bird Last Year
Posted 8 Months Ago
Last Active: 1 hour ago
Posts: 4.6K, Visits: 39.3K
There are a thousands round a bout ways to get this done but none better than a rebuilt or new damper and a proper tool. Even it you only do it once. When I was young I hate to say removal was often with a hammer and pry bar and installation was with a hammer. A rubber hammer if it went easy and progressively bigger hammers if it didn't. Of course being careful to hit the center area only! Smile
Never lost one but that was just dumb luck and limited rebuilds as a teen.
Posted 8 Months Ago
Posts: 3.7K, Visits: 323.8K
My teenage trick was to heat the hub area with my propane torch until a wisp of smoke rose from the hub then used Moonshadow's method of using a proper sized hammer to  tap the damper in place, striking the central part of the damper.
Posted 8 Months Ago
Posts: 3.7K, Visits: 498.2K
Ive done it tin a similar way with the same result.
RamVet (1/2/2026)
Recently removed a damper from a 312 and it was snug.  Sent it to Damper Dudes (highly recommend) and they made it new again.  Wanted to be careful putting the damper on since it felt snug by hand.  Got about an 8" piece of steel all-thread that was the same as the crank bolt (can't remember threads off the top of my head).  Slid the damper on the crank snout (with grease), threaded the all-thread into the crank, slid a crank washer and short piece of pipe and another washer on the all-thread.  Ran a nut down to the pipe and put double nuts (tightened together) on the end to hold the all-thread.  Twisted the nut by the pipe the pipe to apply pressure while holding the nuts on the end.  Damper went on with no drama and the all-thread protected the threads in the crank.  Something to consider.
Posted 8 Months Ago
Last Active: 4 hours ago
Posts: 2.0K, Visits: 306.6K
... center thrust bearing be damned ...
HARRY ARMSTRONG, HEAT AND BEAT and BFH at some point will cost $$$.
If you cannot rent or buy the needed SPACIAL SERVICE TOOLS, it is best (IMO) to leave it alone and pay a QUALIFIED TECH to perform the service repair.
Let the HATE begin ... http://forums.y-blocksforever.com/uploads/images/215ddddd-3895-4223-84e0-e8e4.gif
