Rocker Stand Bolts
Posted By Dad's Bird Last Year
Dad's Bird
Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)Normally aspirated (34 reputation)
Posts: 13, Visits: 116
Any of you Y-block gurus know which of the bolts shown are original? I have two engines torn down and they both have the necked down bolts without markings and some of the grade eight bolts. Who knows what's been done over the years but I'm just curious what's original.
Thanks.
'55 T-Bird
Battle Ground, WA
cokefirst
Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)Supercharged (415 reputation)
Posts: 168, Visits: 2.4K
The ones with the unmarked heads are correct.  They are a grade 2 bold which is plenty strong enough for the job.  Ford and other manufacturers used grade 2 bolts in lots of places where they don't need the extra strength.  The grade 8 bolts are overkill in this application.
Dad's Bird
Thanks for that. Since I like symmetry and am building one engine from two I'll use all of the originals in this engine.
'55 T-Bird
Battle Ground, WA
Posts: 2.0K, Visits: 306.6K
Maybe this will help -
http://forums.y-blocksforever.com/uploads/images/d0a36e6b-af81-4ea2-a72c-6ffd.png
http://forums.y-blocksforever.com/uploads/images/7b5d4132-0e61-46ab-8405-b33b.png
http://forums.y-blocksforever.com/uploads/images/81eccf7d-d812-45af-975a-a639.jpg
http://forums.y-blocksforever.com/uploads/images/c2e408e7-7628-40b0-b573-aa13.jpg
Dad's Bird
Wow, there is so much knowledge amongst this sites members!
Thanks all for sharing!
'55 T-Bird
Battle Ground, WA
Daniel Jessup
Posts: 2.0K, Visits: 131.2K
The third bolt from the left with no markings on the head - that is your bolt!
Daniel Jessup
Red Lion, Pennsylvania
FORD DEARBORN
Posts: 841, Visits: 113.5K
Interesting to note the "grip" area on the shank just under the bolt head. Looks like only the original Ford bolts have that self centering/alighment feature design into the bolts.
