Radial tire shimmy
Posted By geo56 Last Year
geo56
Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)
Last Active: 7 hours ago
Posts: 157, Visits: 7.0K
I tried to buy a new set of whitewall tires locally a while back for the front on my 56 Victoria. I ended having to search on line and bought a set of 3/4 inch whitewalls of an off brand (Tornel Classic). When I went to scrub the whitewalls I noticed one or two divots or lumps on each sidewall. They seemed to ride ok but as of late the front of my car shimmys from side to side noticeably as I drive in town from stop to stop. But when I speed up , like over 40 mph the shimmy smooths out completely and is not noticable at all. I did raise the car off the ground and gave each front wheel a spin and did not notice any sideways wobble on the tread and no noticable bumps in the tread. I hope someone who is knowledgable on radial tires can advise me on if this is a safety issue. By the way, I have been searching on Diamondback and Coker and really like the radial tire with the bias ply look. Very pricey, but what I have now is probably cheap off shore junk. I know the 56 Fairlane had wide whites but I prefer the 1 inch whitewall that was popular in the mid 60's.
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Posts: 1.3K, Visits: 1.9K
I have never heard of "Tornel Classic." Take the car back to the shop that installed the tires. They need to check the balance and make sure that the tires aren't out of round. Point out the bulges as well.Hopefully you didn't buy the tires online. It's also possible that one or more balance weights fell off.
If your vehicle is a driver, not a show car, buy the best tires available in the correct size.
geo56
Yes I did buy the tires on line as whitewalls are no longer available locally. The shimmy is at low speeds going from stoplight to stoplight in town and smooths out to nothing noticeable at highway speeds.
Lou
Posts: 564, Visits: 8.4K
The tire or tires are out of balance (way out). Most likely they were balanced using a spin balancer , see if you can find someone with an old fashioned bubble  balancer (good luck). I have a bubble balancer and have fixed this problem for 10 or 12 people in the last 30 years.
PS...Wash the rims front and back before balancing .
Joe-JDC
Last Active: 4 hours ago
Posts: 777, Visits: 22.8K
A steel cord belt that has not sealed properly in the manufacturing process will never balance out.  The steel will oscillate forever.  See if the beads/tread run perfectly straight on spin test.  You can see the oscillation/waver if that is the issue.  BTDT.  Joe-JDC
geo56
Would that explain why the shimmy seems to smooth out at higher speeds. I did mention that I felt divots in the sidewalls when the tires were new and I was scrubbing the whitewalls to get the blue soap off.
An out-of-round tire might not balance. It might be necessary to have tires trued, which involves shaving the tread, thereby reducing tread life.
geo56
Not worth the expense for a cheap set of tires made in Mexico for a company in India. Tormel Classic. I will probably cut my losses and try Diamondback or Coker for a 1 inch radial with the bias ply look. What good is buying cheap off shore junk if you can't even use it safely?
Although I have not purchased either, Diamondback seems to have a better reputation.
Posts: 1.8K, Visits: 306.4K
Were the tires mounted on 1956 steel wheels?
A radial requires a later style wheel. The earlier steel wheels may/will flex.
But if you felt bulging in the sidewalls, I would shake them, maybe try a warranty claim.
