Posts: 2.0K,
Visits: 306.5K
Maybe give this guy a call and describe the situation. Tell him the carb has been modified by PONY and that you want to retain the calibrations as he finds them but need a complete rebuild to make it serviceable. If it needs donor parts and he doesn't have them, I am sure we can find them. - http://www.thecarbshop.com/home.html
Last Active: 4 hours ago
Posts: 1.8K,
Visits: 154.5K
Robs36Ford (9/2/2025)
Another thing that can make bubbling noise is low coolant It also occurred: I have a PCV/phenolic spacer. Bubbling noise could be from crankcase pressure (?), though my oil-fill breather cap isn’t likely clogged.
6 VOLTS/POS. GRD. NW INDIANA
Visits: 498.2K
It is possible that it is not a carb issue. A lot of time when things go bad after warming the engine up up it can be an electrical or mechanical issue.
Another possibility is a leaking intake manifold gasket. Have you tried just retightening the intake manifold bolts? How does the top fuel cover gasket on the carburetor look? Your symptoms points to too much air coming into the air bleeds and a worn or broken gasket can do that. The choke is likely compensating for this when the engine is cold assuming that the choke is functional. If you can give me the stamped number off of the top of the fuel bowl cover, I might have an extra cover here which would at the very least, take care of the boogered up air cleaner stud hole. That enlarged A/C hole could be the source of your issues.
Posts: 1.8K,
Visits: 154.5K
? The stripped threads are in the float bowl, not the cover. A replacement cover would be appreciated, since mine is damaged, but the rebuilder would likely need another bowl also, though I suspect many used ones have bad threads too, from over-tightening the AC wing-nut. Cover gasket is new, BTW. An air horn seal failure is a possibility, since trouble started when I reestablished the cover’s vacuum seal. I’ll check the manifold bolts though.
Posts: 1.8K,
Visits: 154.5K
paul2748 (9/6/2025)
It is possible that it is not a carb issue. A lot of time when things go bad after warming the engine up up it can be an electrical or mechanical issue. Yes, I need to check over the other systems. Though coincidence unlikely, it does happen.
Posts: 1.8K,
Visits: 154.5K
It occurs, since a recent overheating incident (radiator hose came off) may have warped a head, and the symptoms of misfiring/stalling after warmup likely indicate one of the 50+ yr. old steel head gaskets may have finally failed, that is the possibility I’m inclined to investigate next. Only, if so, how to explain the bubbling/gurgling sound coming from the carb after shutdown (?).
