By DANIEL TINDER - Last Year
Rough running/exhaust popping/hard starting after warmup, plus bubbling sound from carb area (eventually dies down, but returns upon throttle fully opened). Starts & runs normally when cold though. Carb mod has power valve continuously open, btw. Ideas?
By Robs36Ford - Last Year
Sounds like lean, Check fuel pump for weak pressure or flow .... ?
By Ted - Last Year
The vacuum for the power valve on the model 4000 Holley is independent of the spark advance valve. The power valve is the brass valve between the main jets in the fuel bowl while the spark advance valve is located on the side of the carburetor. What carb modification are you referring to? Are the idle mixture screws responsive? Screwing them all the way shuts off the engine? One to one and half turns out on each is normal for a stock camshaft. Any vacuum leaks will upset the idle and cause the popping noise you mention.
Robs36Ford (8/25/2025)
Sounds like lean, Check fuel pump for weak pressure or flow .... ? No change when I switch on the electric auxiliary pump.
Ted (8/25/2025)
The vacuum for the power valve on the model 4000 Holley is independent of the spark advance valve. The power valve is the brass valve between the main jets in the fuel bowl while the spark advance valve is located on the side of the carburetor. What carb modification are you referring to? Are the idle mixture screws responsive? Screwing them all the way shuts off the engine? One to one and half turns out on each is normal for a stock camshaft. Any vacuum leaks will upset the idle and cause the popping noise you mention. Carb mod: Oversized AC stud attached to the float cover (threads in body stripped), but not sealed, thus no vacuum to close the power valve. Normal running when cold, and bubbling noise from carb area (returning when throttle floored) after warm shutdown is what’s puzzling.
By Ted - Last Year
Looks like we are back to the engine running lean when it’s hot. You might try disconnecting the distributor vacuum line and see if that helps. Beyond that, then low carburetor float level, vacuum leak(s), idle mixture screws improperly set, valve lash, ignition timing are just a few other things to look at.
By paul2748 - Last Year
Sounds like you need another carb. Shouldn't be that hard to locate another 55 teapot
DANIEL TINDER (8/26/2025)
Carb mod: Oversized AC stud attached to the float cover (threads in body stripped), but not sealed, thus no vacuum to close the power valve. Normal running when cold, and bubbling noise from carb area (returning when throttle floored) after warm shutdown is what’s puzzling. [/quote]
paul2748 (8/26/2025)
Sounds like you need another carb. Shouldn't be that hard to locate another 55 teapot.
I’ll likely just finally install the modern Holley I have put aside, and leave the teapot issue to whatever restorer ends up with my car 😁 (after I check the possibilities that shouldn’t only occur when engine warms, or causes a bubbling sound). P.S. I wonder, if anyone has filled the market void left when PONY went out of business? Seems like most current rebuilders lack that same level of tech sophistication.
My quoted post text disappeared (go figure). Was just curious if anybody has filled the market void left when PONY went out of business? (Same level of tech sophistication).
Are you looking for a rebuilder for your teapot ? These guys specialize in teapots:
Sal Cicala 586-612-1650 David Arey 610-837-6146
DANIEL TINDER (8/27/2025)
paul2748 (8/27/2025) Are you looking for a rebuilder for your teapot ? These guys specialize in teapots: Sal Cicala 586-612-1650 David Arey 610-837-6146 One has no cores or parts, the other seems less than technically responsive.
By KULTULZ - Last Year
CHECK THIS OUT - https://www.hotrodreverend.com/post/1955-ford-holley-4000-rebuild
Also - https://www.carburetor-parts.com/holley-4000-parts
And - https://www.carburetor-blog.com/article-categories/holley-4000/
https://www.carburetor-blog.com/knowledge-base/4000-rebuild/
It all depends on far you want to go with it regarding rebuild/restoration.
By Ted - Last Year
Daniel. Is your particular carb a List #1077 or #1078? The list numbers will be found at the rear lower flange of the carb. These two numbers were particular to the 1955 Thunderbird. Are you looking to simply repair your carb or replace it? And if replacing it, are you looking for the correct numbered carb for your application or would a non-correct number Holley 4V model 4000 carb be suitable? Here’s the link to a past thread showing the List numbers of the various model 4000 carbs used by Ford. http://forums.y-blocksforever.com/FindPost167355.aspx
Interesting, thanks.
Ted (8/28/2025)
I never thought to check the list # of the refurbished 4000 PONY sold me. Guess I should. Don't know what they did to make it run so much stronger than the locally rebuilt orig (which I now wish I hadn’t sold), but if I could only diagnose my current issue, I would just have it rebuilt (assuming the AC stud threads could be repaired, and I could find a replacement float cover), unless it’s secret could be discerned & duplicated. Once I eliminate other factors (lash, timing, etc.), I may just forget it and install the new Holley & BT manifold though.
"I never thought to check the list # of the refurbished 4000 PONY sold me. Guess I should.
Don't know what they did to make it run so much stronger than the locally rebuilt orig (which I now wish I hadn’t sold), but if I could only diagnose my current issue, I would just have it rebuilt (assuming the AC stud threads could be repaired, and I could find a replacement float cover)"
So the carb you have mounted now is not the car assembly carb but a modified H4000 from PONY CARB (and yes, they were good)? And you sold the original carb? Can you post the LIST NO. of the present carb?
I think Ted has a correct LIST NO(s). core he is offering you. Most likely your present carb needs to be gone through, especially if has running ethanol laced gasoline. Plus it was modified by PONY CARB.
Is your BIRD a driver, survivor or restoration ? Do you plan on restoring it (numbers correct)?
There are services out there that can fully restore the carb further than what I showed above. They (above) are more in the line of service repair.
Maybe these will be helpful -
Looks like a #1078. Car is a driver. Even with mostly premium fuel, 70K miles with any alcohol content likely means it’s due for a rebuild. But, an academic issue if I change to the new Holley. A lot of trouble & expense only to benefit an eventual restorer. I wonder if it would be safe to run the motor with the float cover off? If gas is draining/leaking into the manifold faster than the pump can fill, that might explain the bubbling sound (and why it runs fine initially).
You post 'anther carburetor'. Do you mean you have a later style carb that you want to install (update) rather than repairing the present H4000?
Peruse through this site (lots of TECH) - https://www.carburetor-blog.com/knowledge-base/4000-rebuild/
If you don't come across an answer, maybe call and see if he as an opinion.
I have never been into one. In fact, the first time I actually saw one, it took me a little off as I started with FE with either a F4100 or H4150.
If your present H4000 was gone through and modified by PONY CARB, I would try and have that one repaired. Maybe buy a core for parts.
Let the board know what you decide.
The cover has several of the air bleeds that control the fuel timing at different RPM. Running without, for other than idle and just off idle, would not work well at all. But as a test after the engine is hot, pull it off to see if it is flooding or boiling fuel. Ensure your Fire Extinguisher is handy and charged !
Bubbling sounds are usually the gas boiling due to heat soak or lots of air getting in. Do you have a phenolic carb spacer ? It's 1/2" and black colour under the carb to stop the heat from the intake. Without the spacer the carb WILL get too HOT ! Is your exhaust heat crossover leaking ? that could cause extra flow of hot exhaust into carb area making the fuel boil. I believe the 55 has an intake mounted choke. Was that changed to the later Carb mounted style ? If the fuel filter has clogged and broken that could let dirt into the needle and seat of the carb making it flood the engine. but that would continue even when the engine cools down.
Just a few thoughts.... :-)
KULTULZ (9/1/2025)
New 465 HOLLEY. Manual says elect. choke needs 12V though. I have a small transformer that might work in case. Also have to likely rig the linkage.
Robs36Ford (9/1/2025)
The cover has several of the air bleeds that control the fuel timing at different RPM. Running without, for other than idle and just off idle, would not work well at all. But as a test after the engine is hot, pull it off to see if it is flooding or boiling fuel. Ensure your Fire Extinguisher is handy and charged ! Bubbling sounds are usually the gas boiling due to heat soak or lots of air getting in. Do you have a phenolic carb spacer ? It's 1/2" and black colour under the carb to stop the heat from the intake. Without the spacer the carb WILL get too HOT ! Is your exhaust heat crossover leaking ? that could cause extra flow of hot exhaust into carb area making the fuel boil. I believe the 55 has an intake mounted choke. Was that changed to the later Carb mounted style ? If the fuel filter has clogged and broken that could let dirt into the needle and seat of the carb making it flood the engine. but that would continue even when the engine cools down. Just a few thoughts.... :-)
Car ran great, even with the power valve continuously open (just poor mileage). Believe I’ll warm the motor with only a couple float cover bolts barely snugged, and then pull the cover quickly to check the level. I’ll run only the aux. elect. pump first with the cover off, to check it before starting. If the crossover IS leaking, then the teapot issue is indeed null. Carb body doesn’t feel hot though. Mystery is why after the bubbling dies down, opening the throttle starts it again (?).
Another thing that can make bubbling noise is low coolant
"Car ran great, even with the power valve continuously open (just poor mileage)."
This just rang out on me ...
In addition to the mileage, the rich mixture will thin the motor oil.
They didn't call them 'TOWERING INFERNOS' for no reason ..
You need to find a capable re-builder.
Running great? This isn't what you said in your opening post.. Seems like you are expecting to much with a carb that seems to have multiple problems. I have a teapot on my 56, had it rebuild by professional who specializes in teapots and it runs very well. As it was mentioned, running very rich can thin out the oil
By cos - Last Year
Hello Seem like Ford cook book said to cut part of top cover off (leaving essential part) so you can see inside of bowl for fuel level. I did it.
paul2748 (9/4/2025)
Opening post was only due to a sudden problem, which would seem obvious. Diluted oil an unlikely cause though. Why don’t you try to explain why it still runs great initially when cold, with a carb that has multiple problems?
Site won’t post my quote text.
'Diluted oil an unlikely cause though.'
It is not a cause but a result.
'Why don’t you try to explain why it still runs great initially when cold, with a carb that has multiple problems?'
If it runs good at cold start up and then worsens as the car warms, it is indicating a rich condition with the choke on and as the choke opens it goes lean, possibly a vacuum leak.
https://www.mustangtek.com/Library5/PDF/Holley4000.pdf
https://duckduckgo.com/?q=HOLLEY+H4000+4V+REBUILD&t=newext&atb=v420-1&ia=videos&iax=videos&iai=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DqtCR6uwcnGg
Maybe give this guy a call and describe the situation. Tell him the carb has been modified by PONY and that you want to retain the calibrations as he finds them but need a complete rebuild to make it serviceable.
If it needs donor parts and he doesn't have them, I am sure we can find them.
- http://www.thecarbshop.com/home.html
Robs36Ford (9/2/2025)
It also occurred: I have a PCV/phenolic spacer. Bubbling noise could be from crankcase pressure (?), though my oil-fill breather cap isn’t likely clogged.
It is possible that it is not a carb issue. A lot of time when things go bad after warming the engine up up it can be an electrical or mechanical issue.
By Ted - Last Year
Another possibility is a leaking intake manifold gasket. Have you tried just retightening the intake manifold bolts? How does the top fuel cover gasket on the carburetor look? Your symptoms points to too much air coming into the air bleeds and a worn or broken gasket can do that. The choke is likely compensating for this when the engine is cold assuming that the choke is functional. If you can give me the stamped number off of the top of the fuel bowl cover, I might have an extra cover here which would at the very least, take care of the boogered up air cleaner stud hole. That enlarged A/C hole could be the source of your issues.
? The stripped threads are in the float bowl, not the cover. A replacement cover would be appreciated, since mine is damaged, but the rebuilder would likely need another bowl also, though I suspect many used ones have bad threads too, from over-tightening the AC wing-nut. Cover gasket is new, BTW. An air horn seal failure is a possibility, since trouble started when I reestablished the cover’s vacuum seal. I’ll check the manifold bolts though.
paul2748 (9/6/2025)
Yes, I need to check over the other systems. Though coincidence unlikely, it does happen.
By DANIEL TINDER - 4 Months Ago
It occurs, since a recent overheating incident (radiator hose came off) may have warped a head, and the symptoms of misfiring/stalling after warmup likely indicate one of the 50+ yr. old steel head gaskets may have finally failed, that is the possibility I’m inclined to investigate next. Only, if so, how to explain the bubbling/gurgling sound coming from the carb after shutdown (?).
