PARTS FOR SALE
Posted By Doug T Last Year
Doug T
Posts: 563, Visits: 2.6K
http://forums.y-blocksforever.com/uploads/images/68cbddcf-ff1d-4278-a050-f843.jpghttp://forums.y-blocksforever.com/uploads/images/546bf32f-5712-44ca-9ca8-ab96.jpg
The following items are for sale, located in Louisville KY, and are ready to ship.  The weight is estimated and the cost to your location should be included with the payment. An offer of the stated price will be immediately accepted.  I will need payment by Zelle and I will dispatch by USPS quickly.  Please correspond by Email: my address is Yblocker@hotmail.com.   Best Regards D. Thrasher
 1)     262 copies of Y-Block Magazine. Volumes 1 – 9complete and bound in blue plastic covers, these copies have been hole punched for 3 hole binders. Volumes10 – 19 and 21 and 22 complete, 6 mixed issues and volumes 27-28 having a total of 8 copies. I will not ship separate copies or volumes, the entire 262 copies must go together.  Weight 32lbs. price $250.00
NOTE, The following parts are all removed from a 1957 Ford Y block motor.
   Generator bracket pieceshttp://forums.y-blocksforever.com/uploads/images/c65bb3aa-aa85-4e64-a3ea-32c3.jpg  These 3 pieces plus assembly fasteners support the generator in the stock position on cars and truck but not Thunderbirds. They can be easily converted to support an Alternator.  Est. weight 2#  price $30.00
    Power Steering Bracket.  This bracket bolts to the back of the P.S. pump and is steadied by the bolt at the front of the left side Ex. Manifold.  Est. weight 1#  price $30.00
http://forums.y-blocksforever.com/uploads/images/63c2464a-cb21-4528-a179-0734.jpg
Harmonic Damper with w.p. and gen. pulley.  Appears to be in good condition but needs a sleeve over the seal area. Est. weight 10# price $40.00 Used on most Y blocks except Thunderbirds and H.D.Trucks
http://forums.y-blocksforever.com/uploads/images/bb120035-f6da-4971-82dc-c928.jpg
  Exhaust diverter damper.  Bolted between the right side ex manifold and the right side head pipe, this damper diverts warm exhaust under the carburetor to speed up warm up of the carb and mixture. The bimetallic coil works and the shaft is free turning on this unit.  Est. weight 1 # price $50.00
http://forums.y-blocksforever.com/uploads/images/e9a6c8e0-06f0-43c2-9bcd-feef.jpg
Thermostat housing.  Goes on front of intake manifold.  The flange is flat, there is some pitting outside and inside of the housing. The water bypass tube is present and usable.  Not show condition but fully functional Est. weight 1#, price $10.00
http://forums.y-blocksforever.com/uploads/images/c54181df-d57f-45a1-ae36-5b38.jpg
   Thunderbird Rebop aluminum water pump spacer. Fits between the timing chain cover and the water pump on a THUNDERBIRD only. This item is not needed on a passenger car or truck of any year.  Est. weight 1#  price $25.00
http://forums.y-blocksforever.com/uploads/images/afc0de5f-04a0-48ff-9b4e-f742.jpg
NOTE, The sources of the following parts are unknown unless a vendor is shown.
     Two Bendix starter drives.  These appear to be Y Block but have not been tested. Est weight 2# price $15 for both
Mustang Type Shifter.  The exact application for this shifter is unknown but seems to be 1966 vintage. The chrome housing has C5ZA AND a C4ZA prefixes to the part number.   It needs a new rubber shield around the shaft. Est. weight 5# price $60.00http://forums.y-blocksforever.com/uploads/images/3f440e5f-52bb-46ec-8611-ef19.jpg
 Ford Y block front motor mount bought for a 1956 pickup. Never used.  Est. Wht.1#, price $20.00
http://forums.y-blocksforever.com/uploads/images/89f60573-ce1f-47f9-93f8-b1db.jpg
   Speedway Motor Mount cushion kit #720-9314, never used these are typically used under some early flatheads, Speedway price $35.99, Est. Wht.1#, price $15.00
http://forums.y-blocksforever.com/uploads/images/1d711348-df86-4c38-8edf-df58.jpg
   Hurst Universal T-Handle Shifter Kit in unopened original container.  Complete including several threaded sleeves to adapt to Hurst Shifters and domestic and foreign OEM shifters.  Carried by Summit as#153-0020 at a cost of $49.00+ Est. weight 1# price $25.00
http://forums.y-blocksforever.com/uploads/images/db1c4fc8-c27a-4e33-a23a-f993.jpg
A pair of 1963 Falcon Taillights.  These are spun aluminum and the shine has faded on the exterior. They have their original black exterior gaskets. One of the housings has slight bending of the rim.   The red lenses are damaged and should be replaced. Sockets and wiring are usable. Wht. 2# price $20.00
http://forums.y-blocksforever.com/uploads/images/bb90ea98-789b-4abe-ac6e-91a5.jpg
I sort of regret using all this band width but it beats sitting in a hot swap meet.
D.T.
Doug T
