Phenolic spacer question
Posted By geo56 Last Year
geo56
Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)Supercharged (413 reputation)
Posts: 157, Visits: 6.9K
I am in the process of returning my 56 Victoria with 292 and Fordomatic back to original by switching back to the originjal A manifold and Holley 4000 . I have rebuilt and modified the carb to run with the later distributer and have replaced the heat tube in the manifold. Why am I going backward with the swap? I have run a 450 cfm Holley with manual choke on a B manifold for several years and have been happy with warm weather driving. On the other hand, even in mild Tulsa winters, cold weather driving has been a challenge, especially at stops before the engine has become warmed up. The holley carb was intended for a 289 and as my spark plug readings showed pure white without any hint of brown, I think my Holley might be too lean for the 292. I tried adding the heat riser valve a while back and it didn,t help and only made my exhaust pipe hang low enough to rattle against the frame. Anyway, I am hoping the swap will enable me to have a better cold weather car that I can walk away from while it is warming up and not have to do brake stands at stop lights. I was wondering if anyone knows if a phenolic spacer is available for the Holley 4000. My purpose would be to avoid vapor lock on hot days. Also , would I hurt anything by leaving out the heatriser valve. By the way, I am not a hot rodder and desire a car that runs as smooth and efficiently as it did when new.
Deyomatic
Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)Supercharged (868 reputation)
Posts: 299, Visits: 2.5K
Sounds like your mind is made up but did you ever play around with jets in the 450?
I have no clue if these are the correct measurements, and it is aluminum, but that shouldn't be a problem.
https://www.dashman.net/product.php?id=249
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Posts: 1.3K, Visits: 1.9K
The 450 cfm Holley is bigger than the Holley 4000 Teapot carburetor; if anything, it should be rich, not lean. If you insist on going backwards, you can purchase a PCV conversion kit from one of the Tbird suppliers. The kit uses a phenolic spacer to which the PCV hose attaches. You could also try installing multiple carburetor base gaskets.
Personally, I would work on getting that 450 cfm carburetor dialed in.
Posts: 1.8K, Visits: 306.4K
An automatic choke on a carb setup has to be adjusted correctly (specs in WSM) and used in conjunction with a heat riser (properly maintained and functional). The choke may have to be calibrated (adjusted) according to the temps/humidity where you live. Correct fuel curve and balance, correct engine state of tune.
HERE - https://www.ebay.com/itm/267324854653?var=0&toolid=10044&loc_physical_ms=92810&customid=c37b59229d6d1b8f6f0631b70e52cbba
