11” clutch
Posted By montana ford man Last Year
Posts: 1.8K, Visits: 306.4K
Is it a 272 or 292?
10in DIA & 10 SPLINE?
Are all linkages/bushes good? ADJ correct?
Where did you source the clutch?
montana ford man
Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)Supercharged (405 reputation)
Posts: 166, Visits: 23.9K
I ordered a clutch kit for my 55 crown Victoria. It said it was for a 55 ford car. When it arrived it was an eleven inch clutch and pressure plate with a fine spline clutch disc. My car has a 10” course spline disc. Was this clutch for a thunder bird? Had to send it back or figure out a different flywheel.  After putting everything together my clutch grinds when on the floor and the transmission won’t go into gear   I’m thinking bad pressure plate
