55 Mercury intermittently won’t crank with key
Posted By Jazzmeister Last Year
Jazzmeister
Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)
Posts: 8, Visits: 1.3K
Hey guys, I have this issue with my ‘55 where it will occasionally fail to engage the starter when turning the key to the start position. Sometimes if I hold it in position it will suddenly go, sometimes I release and try again. Eventually it will work normally, and mostly it works on the first try. It’s just a little unsettling because when it doesn’t work, it does absolutely nothing, no click. No noise at all. It never has stopped mid-crank. I suspect something between the switch and the starter solenoid, but wondered if you might have other ideas. This is still a 6v system.  I edited my post here, because I think the relay that sits above the solenoid is for the horn, but seems to work when I jiggle the wires to it, maybe just coincidence.  Thanks for any advice!
