Drivers side window rear channel guide
Posted By MoonShadow Last Year
cos
Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)Supercharged (561 reputation)
Last Active: 4 hours ago
Posts: 198, Visits: 119.6K
Hello  Guys over on 57 Ford forum tell of using Velcro to reline channel if that what you a asking about.
Posts: 1.9K, Visits: 194.9K
Restoration Specialties is who I used on the bird. The tbird suppliers have the rivets and setting tool if your’s uses those.
The adjustments are a pita, everything you move seems to affect something else. Even worse on the bird, trying to find what’s best between 2 different tops.
But my power windows work fine. Just takes time.
As an aside, if you need new rollers, Casco (and others) now have metal, USA made ones. The plastic ones tend to break. I know, the hard way.
Posts: 3.7K, Visits: 497.9K
Check with Restoration Specialties in PA.  They have a lot of runners and may have something to help you out.
Posts: 4.6K, Visits: 38.8K
My guide that the back of the glass rides in has lost its liner. This is on a 56 Victoria and has an odd shape with sort of a double channel. One about 1/2" wide and another at the bottom of that about 1/8" wide. Does anyone have a good replacement or know a way to put new liner in? I'm also open to any tricks on adjusting these guides my windows are hard to roll up and down and the gaps to the roof are very hard to get right.
