Anyone have a good PCV solution for a 368 Lincoln Y Block?
Posted By Daniel Jessup 7 Months Ago
Daniel Jessup
Question Posted 7 Months Ago
Posts: 2.0K, Visits: 131.0K
Not my engine but trying to help a guy that has a 368. What would be a good way to add PCV to a mid-50's Lincoln Y Block? Are there any companies that would sell a kit like CASCO does?
http://forums.y-blocksforever.com/uploads/images/54a550ae-04dc-4d72-9c74-c1b.jpeg
http://forums.y-blocksforever.com/uploads/images/f1e5a15f-5c34-4f24-8ad6-551.jpeg
Daniel Jessup
Lancaster, California
Posted 7 Months Ago
No road draft tube?  The picture makes it look like just an exposed slot at the back of the valley cover for venting purposes.
Posted 7 Months Ago
Posts: 1.8K, Visits: 306.3K
The way I would go about it is basically the same as the FYB.
The road draft tube is located @ the front of the engine. The valley cover is the same basic design as the FYB. You would simply modify the valley pan as the FYB PCV COVER (rear valve mount) and supply the vacuum signal with a carb spacer with vacuum tube outlet.
The front mounted oil filler/road draft tube would be modified (using expansion plug to block open road draft tube) to make the actual road draft tube non-functional but to still have the filler tube for function/appearance.
http://forums.y-blocksforever.com/uploads/images/b82ab702-d9ab-4b0a-a3e8-31b0.png
http://forums.y-blocksforever.com/uploads/images/2be5fb4f-cd7b-4eb7-add7-8591.png
Reply and we can take it further.
Daniel Jessup
Posted 7 Months Ago
"You would simply modify the valley pan as the FYB PCV COVER (rear valve mount) and supply the vacuum signal with a carb spacer with vacuum tube outlet."
This is exactly what I told the owner - I do not know of any off the shelf kit or if Ford ever had a PCV valve from the factory like they did for Ford Y Blocks in the 60's.
Thank you Ted and Kultulz.
Daniel Jessup
Posted 7 Months Ago
The PCV SYSTEM was introduced on the 1960 model run (CA). FYB (not all) got it but I believe the LYB (302-332 TRUCK) stayed with rear mounted road draft until retirement.
http://forums.y-blocksforever.com/uploads/images/bb404010-2105-4ad0-83be-5431.png
FORD DEARBORN
Posted 7 Months Ago
Last Active: 5 days ago
Posts: 789, Visits: 113.4K
I don't have an answer for adding a PCV valve to the Lincoln Y-block but would like to mention or question a coupe of things.  On the Ford Y the crankcase vapors exit through the port on the valley cover which has a well designed baffle under that port. The port on the Lincoln valley cover is where atmospheric air enters the engine. I'm wondering if there is any kind of baffle in that area?  I would also guess the oil filler cap on the Lincoln Y is not vented so if the road draft tube at the fromt of the engine was blocked, a vented filler cap would be needed for air to enter at this point as on a Ford y.  If in case I don't have a proper understanding of the Lincoln vent system, please accept my apologies.
Posted 7 Months Ago
No, it seems you have a better understanding than I do ...
That is the fresh air intake on the front of the valley cover (filtering media).
http://forums.y-blocksforever.com/uploads/images/2739cf77-a872-40d0-9a1b-bdb0.png
http://forums.y-blocksforever.com/uploads/images/11ef39ab-828e-44bb-8e12-c50a.jpg
There is no baffle directly under it, although there is an air deflecting baffle midway same as the FYB. This allows airflow to enter the top of the cylinder heads, so front to rearward air flow must be the same as a FYB?
The later HT 302/332 shows a rear mounted draft tube.
The front mounted oil filler tube/road draft (6758) allows oil fill and road draft so there must be baffling in that canister.
I have a 1957 MERC WSM somewhere. Let me find it and see what the CCV flow chart shows and will be back.
This changes the above suggestion for PCV modification.
THANX FOR THE WAKE-UP CALL!
