Cast Valley Cover. Where can I buy One?
Posted By oldcarmark Last Year
Posts: 3.8K, Visits: 33.2K
I received a brand new Mummert Pan from Stuey in the UK. Exactly what I was looking for with PCV fitting. I want to say thanks to Stuey. Really appreciate You helping Me out. Got it in 6 Days to Canada in perfect Condition.
Outlaw56
Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)
Posts: 436, Visits: 26.9K
How does th valley pan accept a pvc fitting? Does the valley pan have a baffle underneath it? Does the hole in the valley pan take just a groumet the PVC plugs into or does a stock tpot plug into the hole then the rubber hose to the PVC Valve?
Posts: 3.7K, Visits: 498.2K
 I have two of John's valley covers.  They have an oil baffle underneath.  The hole uses a grommet and you use a push in valve.  If you have a  stock t-pot carb, then you have to get the plate that goes between the carb and the manifold.  The suppiers sell a kit with the plate which includes the plate, the valve, grommet and hose (CASCO & Hill's).  The valve is the push-in kind.  If you have a Tbird, the kit may be  tight because of the hood.
Outlaw56 (12/1/2025)
