Cast Valley Cover. Where can I buy One?
http://forums.y-blocksforever.com/Topic168257.aspx
By oldcarmark - Last Year
Anyone have a  source for new Cast Valley Cover with Oil filler Pipe and possibly PCV opening in back of Cover. Nobody in the usual Sources have them. Out of stock and no delivery Date. USA source preferred. Thanks
By 55blacktie - Last Year
ACE. They are in New Zealand. Being that they cost well below $800 threshold for import duty, there shouldn't be a tariff.
Although the ACE valley cover doesn't have a baffle for the PCV valve, you can use a Moroso 68772 PCV grommet/w integrated baffle and a Microgard 2322 PCV valve. The Moroso 68772 was just a bit loose when installed in my ACE valley pan, but a bit of black RTV took care of it.
Unlike the OEM valley pan, the ACE (and other aftermarket cast aluminum valley pans) don't have the large baffle/divider near the center of the underside. Unlike the OEM cover, however, the ACE pan does have a small baffle at the bottom of the filler/breather tube; for that reason, I don't think the large baffle/divider is needed.
By Joe-JDC - Last Year
Last time I talked with Geoff Mummert, they were thinking of casting another run of the valley covers.  If enough people asked for them, maybe they would try to cast another run of the valley covers, and timing covers.  Joe-JDC
By Blind Willie - Last Year
This vendor might be an option but I have no personal experience with them: www.rexhp.com.
http://forums.y-blocksforever.com/uploads/images/90b0b7ce-9685-4436-8cdc-6c3.jpeg
I looked into this One. VERY Expensive and I don't need Fancy. Thanks
By stuey - Last Year
Hi oldcarmark
I'm in the UK and I have one. The wife is worried I'll pass away and leave her with a monumental clear up job so I have to start some where..
It's never been used/fitted .
Not sure how send stuff to Canada (customs declarations etc.)  but I could give it a go..
If it arrives safely I would appreciate postage refund only.
stuey
It was announced on the news yesterday that President Trump has removed the import-tax/tariff exemption for items that have a declared value of less than $800.
Sent a PM Stuey. Thanks
By MoonShadow - Last Year
Search EBAY there are a couple on there now.
By lazylnm - Last Year
Purchased one of these a few months ago.  Nice casting.  Wish it had a few more ribs...
Haven't checked flatness yet.  Nice mill finish filler tube with cast collar, No PVC fitting.
Y Block Ford Valley Pan With Filler Tube 312 292 272 Valley Tray | eBay
Mike
'55 Crown Glasstop
272 OD
I received a brand new Mummert Pan from Stuey in the UK. Exactly what I was looking for with PCV fitting. I want to say thanks to Stuey. Really appreciate You helping Me out. Got it in 6 Days to Canada in perfect Condition.
By Outlaw56 - Last Year
How does th valley pan accept a pvc fitting? Does the valley pan have a baffle underneath it? Does the hole in the valley pan take just a groumet the PVC plugs into or does a stock tpot plug into the hole then the rubber hose to the PVC Valve?
By paul2748 - Last Year
 I have two of John's valley covers.  They have an oil baffle underneath.  The hole uses a grommet and you use a push in valve.  If you have a  stock t-pot carb, then you have to get the plate that goes between the carb and the manifold.  The suppiers sell a kit with the plate which includes the plate, the valve, grommet and hose (CASCO & Hill's).  The valve is the push-in kind.  If you have a Tbird, the kit may be  tight because of the hood.
Outlaw56 (12/1/2025)
