Clutch release rod and equalizer bar for 57 Custom
Posted By Marc Last Year
Marc
General Posted Last Year
Last Active: 11 days ago
Posts: 185, Visits: 5.5K
Looking for a clutch release rod and equalizer bar for a 57 custom.
Removed mine while replacing the steering box, and found some heavy wear in the hole end of the rod and the corresponding pin on the equalizer bar.
I imagine at this point they've all got some degree of wear at these locations, but if anyone has a set in better shape than those pictured here let me know.
http://forums.y-blocksforever.com/uploads/images/3535804a-cd30-4c7f-a6b8-7ba6.jpg
http://forums.y-blocksforever.com/uploads/images/0630efbd-7afd-443b-b5fd-506b.jpghttp://forums.y-blocksforever.com/uploads/images/65be395a-5b5d-47d9-9f02-97fd.jpg
Joe-JDC
Posts: 789, Visits: 23.2K
Weld both of them up and grid/polish the weld back to original shape.  Will last a lifetime.  Weld is harder than original.  Joe-JDC
Marc
That thought had crossed my mind. If I'd ever learned to weld I probably would've gone that route already.
It's tough to see in the pics, but it looks like the rod had been repaired that way already at some point. I suspect that accounts for the deep wear on the pin, which does not appear to have ever been welded.
If no suitable parts turn up I will probably find someone to do exactly what you suggest.
FORD DEARBORN
Last Active: 4 days ago
Posts: 840, Visits: 113.5K
Marc, visit Dennis Carpenter's web site and under Ford truck clutch parts,  there are many push/pull rods along with some nylon bushings etc etc..  This may not be exact plug and play but could provide some ideas to a solution for your clutch linkage issues?
Posts: 3.7K, Visits: 498.2K
This may be  a long shot, but a guy I know has a lot of 57 Bird parts and may have one of these that will work.  .  Since you have the  length you could talk to him to see if the bird is the same length or longer.  he is a straight up guy.  His name is Adrian Lori, and his number is 570-709-0823
Marc
Thanks for the tips guys. Appreciate you taking the time to chime in.
I know the rod is the same as used on the t-birds, but the equalizer bar is different.
Fortunately I did find a local guy who could weld mine and get them back to spec. At this point I think this will be the best way to go.
Vic Correnti
Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)Supercharged (713 reputation)
Posts: 350, Visits: 12.3K
You can make one up with a heim joint and 3/8 threaded rod.
