Visits: 752
Im looking into adjusting speed with tire size instead of changing gearing, going from a 26" tire to under 30 inch i have a 57 ranchero with a 4" drop blocks (too much), 15x8 4.5bs welds with a 215/65/15 (26") with only contact coming from driveshaft to body when i was picking up a 292 and fmx. mearuing it looks like backspacing of 5.5" is safe and can use a fairly tall tire without any close contact areas. the issue i come across is the fender rolling in, limiting me to sections width around 9 and tread width under 8.
Posts: 1.4K,
Visits: 2.0K
A 30-inch tire is a tall tire to put on a 57 Ranchero/w 4-inch drop.
Visits: 752
Drops is getting cut at least in half, but a skinny 30 would fit even that low until a bug lands in bed then your rubbing. Most likely going to be 2 inch drop and around a 28 inch tire.
Posts: 2.0K,
Visits: 306.7K
- TIRE - WHEEL - FITMENT TOOL - Percy's WheelRite - The 'lip' where the quarter and outer wheelhouse join can be 'rolled' to increase clearance(s). You have to ensure the rear is centered to frame and doesn't move side to side (worn bushing). Also check for any previous collision/rust repair whereas both quarters hang equally on either side.
Visits: 752
A little update, 57 ranchero 3 in lowering blocks, air shocks @ 0 psi, weld 15x8 4.5 back spacing i put a set of 255/70/15 tires fit nicely. 29.1" tall, 10" sectional width 8.5" tread. would like a little more backspacing because its closer to outer panels by a fair amount. haven't had a chance to drive but plenty of clearance for suspension compression. I'm not sure about body roll yet or how air shocks will effect it.
Posts: 1.4K,
Visits: 2.0K
Why not 65 or 60-series tires, not available? What are you putting on the front?
