Visits: 498.3K
The raised part in the top is for the automatic choke, which was in the right (passenger) side of the carb.. That was for a 56. The 55 choke was located on the intake in 55, so no raised part.
Posts: 1.8K,
Visits: 154.7K
It’s an orig. ‘55 or ‘56 T-Bird oil bath AC. The raised bubble in the base faces up (accommodates teapot carb mechanism). Top is chromed. BTW: I currently have the ‘55/‘56 stainless top repro unit that is designed for a paper filter (modified though for increased airflow, with a larger K&N oiled filter), but when I finally install a modern/larger Holley carb, I may try to modify my original ‘55 oil bath chromed top to mate with a ‘57 repro base (?). If anyone has tried that but found not enough hood clearance, please advise.
6 VOLTS/POS. GRD. NW INDIANA
Posts: 1.4K,
Visits: 2.0K
I didn't download your images; however, if the top is stainless or chrome and looks like a flying saucer, it's a 55-57 Tbird dress-up air cleaner; the base is painted Argent. If there is a cage of sorts that contains a steel-wool-like material attached to the lid, it's an oil-bath air cleaner; if not, it uses a paper element (not oil bath). The raised portion on the bottom allows the air cleaner to clear the OEM choke.The 57 dress-up air cleaner uses a paper element, not oil-bath.
I have seen oil-bath air cleaners that have had the filtration element cut off and replaced with a paper element. I've also seen reproduction lids on Tbird parts sites that can be used with a paper element, in place of the OEM oil-bath lid.
Visits: 9.3K
I have an air cleaner that looks alot like an TB air cleaner. I assume it is oil both, I am not sure how to orient it-note the bottom of the air cleaner has a raised area. See photos. Thanks.
