Visits: 498.3K
If you want a chrome top air cleaner with a paper filter and you are using it in a sedan, try an aftermarket unit. Lots of choices out there. If you are running a later model Holley, that 56 air cleaner will not fit as far as i know.
Posts: 2.0K,
Visits: 306.7K
What CARB style do you have?
This is a repro of FORD open element ACL's used in the mid-sixties -
Skyliner57
Visits: 9.3K
I am going to look at this again. If I were to try an current type filter---does anyone have a good part number? Thanks.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
Interesting approach. Solves the hood clearance, AND airflow volume issues also. I should likely just keep an eye out for any old AC base to cut up that fits a modern 4 barrel (& my current K&N filter). Sounds like a trip to an auto flea market may lurk in future.
6 VOLTS/POS. GRD. NW INDIANA
Posts: 1.9K,
Visits: 195.0K
I didn’t modify the base so much as removed it. I carefully cut the bottom out, the fitted a 3 screws to hole the polished to to the remains of the original base. The bottom and the filter came out of my pile of old parts. But it looks pretty much stock installed. Not a very good picture, but all I’ve got and I’m not around the car right now.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
miker (1/30/2025)
I can’t see a picture and I probably wouldn’t cut up an original anyway. It’s worth too much to a restoration guy. But the reproduction 55 on my bird, made for an element, got cut up to clear an Edelbrock, and mounts and looks just like a the stock unit. If that’s of interest, pm me and post that here so I go check it. I don’t sign in every day. miker: It hadn’t occurred to me that the ‘55 repro base could be modified to fit a modern 4-barrel Holley. I just assumed I’d have to buy a ‘57 repro base. No hurry, but please elaborate whenever. BTW: I also assumed it would be simpler to modify the orig. ‘55 OB top, than have my stainless repro top polished & chromed (?). I suppose the orig. parts shouldn’t be altered though, and it’s sale proceeds might well cover repro/mod. expenses (?).
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
55blacktie: Are you addressing the OP, or me? (I have a NOS 50s dual point Mallory put aside). If the OP still has the Loadomatic, he may indeed not realize how bad his situation is (?).
Posts: 1.9K,
Visits: 195.0K
Posts: 1.4K,
Visits: 2.0K
Although they aren't cheap (what is?), your best bet is to either find a used 57 dress-up air cleaner or buy a new reproduction from one of the Tbird parts suppliers, like Concours, which has frequent 10% off sales, free shipping on most items if you spend $300 +, and no sales tax, unless you live in Nevada. Considering that you're not using a Holley 4000 "Teapot" carburetor, it won't be 100% original anyway, but most people won't know the difference.
I might have overlooked it, but are you going to use a 57-up distributor with that carburetor?
Skyliner57
Visits: 9.3K
Thanks. It is probably a 56, there is steel wool? in a cage under the stainless top. Thanks to all for the response. As stated earlier I have a 312 in a 56 Victoria. However, I am using a Holley 4 BBL. probably not going to be a good fit. I doubt that I can convert this to a cartridge. Thanks again to all who responded.. Harold
