cos
Visits: 119.9K
Hello Members In process of rebuilding a 1956 Lincoln carb for S/C engine. Have a kit from Daytona, it did not come with power valve. Looking for advice for checking to see if is tight. I understand how they work but concerned if valve leaks (in high vacuum) seems like engine would run to rich. May be buying trouble but concerned. Thanks
Posts: 1.4K,
Visits: 2.0K
Contact Sal Cicala.
By design, the power valve is in an open position when the engine is not running. Once the engine is started, engine vacuum pulls the actuating stem ‘up’ and allows the power valve to close. The power valve itself is brass and simply screws into the lower part of the bowl with a gasket. This part does not come in a carburetor kit. There is a number stamped on the power valve indicating the size of the holes in the power valve so that’s another tuning option on these carburetors. The actuating part of the power valve is a spring-loaded rubber diaphragm with a long stem that attaches to the fuel bowl cover with the two secondary jets and a screw. It's this part that is supplied in a carburetor kit. I like to put some white grease on the rubber portion of the diaphragm before attaching it to the cover. To facilitate a better seal, I will lightly depress the plunger while tightening the jets and single screw so that the rubber is flattened out during the tightening process. To check that the power valve actuator will actually work as designed, do the following. With the bowl cover on its back, fully depress the stem of the actuator and then put a finger over the exposed hole that is at the front and center gasket edge of the cover. When releasing the stem, the stem should not move outwards more than 1/8”. Upon releasing the finger from the hole, the stem should fully extend back to its full length. In the event, the actuator will not hold a vacuum, then check that the bronze bushing in the center hole of the bowl cover that is used for the air cleaner stud does not have an air leak. The power valve vacuum channel is behind that brass bushing and if the bushing is not tight within that hole, the power valve will not work. Putting fingers on both side of the carb stud hole while also sealing the exposed hole at the front of the cover with another finger while performing the above test will let you know if there is a problem or not with the bushing within the carb stud hole.
cos
Visits: 119.9K
Thanks Ted Will make sure plunger will hold a vacuum like you advised. The power valve itself, If it leaks with plunger retracted (under vacuum) will this cause a problem? I have put a vacuum source on thread end of power valve, it will not hold. Vacuum probably pulling stem open. I will try somehow to put pressure on plunger end of valve to check for leakage. Should valve have zero bypass? Maybe buying trouble but want to check everything I can.
cos
Visits: 119.9K
Thanks again Ted. Will test in one way or another, with vacuum or pressure. In looking at the pic of valves you have I noticed one with a 44 port, what would that valve been used in, never cone across one that large. I believe original EDB carb used #37 valves but was advised to bore a little bigger.
cos
Visits: 119.9K
Hello Found a chunk of hose with right ID dia. to fit over large end of power valve. By just blowing on hose, valve under water, one was tight other bubbling, leaking.
cos (9/24/2024) ,,,, In looking at the pic of valves you have I noticed one with a 44 port, what would that valve been used in, never cone across one that large. I believe original EDB carb used #37 valves but was advised to bore a little bigger. Thanks for sharing how you performed the test. That was a simple and effective method for testing the power valve. That ‘44’ power valve likely came from a ’56 Lincoln 368 carb. The 43’s came in some of the 1955 Ford/Merc/T-Bird 292 carbs. I have seen those power valves in the 50’s range on the 302/332 LYB truck engines. The ’55 Teapots seem to be all over the map when it comes to power valve sizing.
HazardTBird
Visits: 1.3K
cos (9/24/2024)
Hello Found a chunk of hose with right ID dia. to fit over large end of power valve. By just blowing on hose, valve under water, one was tight other bubbling, leaking. COS That was ingenious!! I will try the same test. Power valves available anywhere if found to be leaking?
cos
Visits: 119.9K
I don't know answer to that question. I have several teapots that I have robbed parts from. Ted might know.
