Holley 4000 teapot carb
Posted By cos 2 Years Ago
Posted 2 Years Ago
Last Active: 9 hours ago
Posts: 2.0K, Visits: 306.7K
https://www.carburetor-parts.com/holley-4000-parts
HazardTBird
Posted 2 Years Ago
Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)Supercharged (124 reputation)
Posts: 50, Visits: 1.3K
Kultulz
I didn't see any power valves on Mike's Carbs site; am I missing it? All kits have the economizer to engage the power valve, spark valve and inlet needle and seat.
Posted 2 Years Ago
Hold On.
I am having a senior moment ... Doze
OK, I am much netter now... A little Jack and Coke brought me back  ...
Is this what you are after - https://www.carburetor-parts.com/holley-enrichment-diaphragm-70-45
There are several calibrations so he will most likely need the CARB ID or if you give me the CARB ID, I can post a PARTS LIST so you can decide what calibration you need.
http://forums.y-blocksforever.com/uploads/images/ac53fa29-ef05-4250-8797-32c8.jpg
Posted 2 Years Ago
Did the above help any?
HazardTBird
Posted 2 Years Ago
Kultulz:
Glad you recovered, I'll be having a recovery in about 3 hrs. If you look at Ted's posts in this thread he has a picture of maybe twenty power valves, a bunch of different drill sizes, that's what I was asking if they are available anywhere.
Posted 2 Years Ago
Nah, what happened is I mis-read your post and for some reason had accelerator pump in my mind (don't ask).
Anyway, yes they are available NOS usually off EvilBay.
The BASIC PART NUMBER is 9594 and is called (by FORD) - JET (POWER).
There are different sizes of course. Are you re-calibrating the 1956 LINC H4000 for a 1957 FORD S/C APPLICATION?
Let me know if you need a special size and I will search through the MPC for your wanted size. They don't give a list of sizes, it is by application.
http://forums.y-blocksforever.com/uploads/images/3d8c8b3d-3f05-4c51-b99c-3224.png
http://forums.y-blocksforever.com/uploads/images/5903310c-e4a2-44bd-8e64-9276.png
http://forums.y-blocksforever.com/uploads/images/f21520ad-60fc-4a2e-8c12-99ae.jpg
RossL
Posted 2 Years Ago
Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)Supercharged (459 reputation)
Posts: 169, Visits: 7.3K
Ted (9/25/2024)
cos (9/24/2024)
,,,,  In looking at the pic of valves you have I noticed one with a 44 port, what would that valve been used in, never cone across one that large. I believe original EDB carb used #37 valves but was advised to bore a little bigger.
Thanks for sharing how you performed the test.  That was a simple and effective method for testing the power valve.
That ‘44’ power valve likely came from a ’56 Lincoln 368 carb.  The 43’s came in some of the 1955 Ford/Merc/T-Bird 292 carbs.  I have seen those power valves in the 50’s range on the 302/332 LYB truck engines.  The ’55 Teapots seem to be all over the map when it comes to power valve sizing.
The power valve in my 55 TBird (4 barrel 292, automatic)  is marked 21, do you think this is too small and causing my hesitation (when I floor the car from a dead stop).   I just ordered a 43   (accelerator pump looks OK)
cos
Posted 2 Years Ago
Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)
Last Active: 7 hours ago
Posts: 216, Visits: 120.0K
Hello  Could or would you  share where you found new power valves?
RossL
Posted 2 Years Ago
cos (10/8/2024)
Ebay search for Holley 9594
Posted 2 Years Ago
Posts: 7.6K, Visits: 206.1K
Here’s a list of Holley 4000 (Teapot) carbs and their original PV numbers.  The Holley List number is used and not the Ford part number.  The application and engine size is shown where applicable.
Carb #            PV#     Application
R-1040A         21        1955 Merc 292
R-1074A         43        1955 Ford & Merc 292
R-1074-1A      43        1955 Ford & Merc 292
R-1074-2A      43        1955 Ford & Merc 292
R-1075A         40        1955 Ford & Merc 292
R-1075-1A      40        1955 Ford & Merc 292
R-1075-2A      40        1955 Ford & Merc 292
R-1076A         43        1955 Lincoln
R-1076-1A       43       1955 Lincoln
R-1076-2A       43       1955 Lincoln
R-1077A         40        1955 Thunderbird
R-1077-1A      40        1955 Thunderbird
R-1077-2A       40       1955 Thunderbird
R-1078A         43        1955 Thunderbird
R-1078-1A      43        1955 Thunderbird
R-1078-2A      43        1955 Thunderbird
R-1094-1A       44       1956 Linc & Cont
R-1094-2A      37        1956 Linc & Cont
R-1094-3A      37        1956 Linc & Cont
R-1094-4A      37        1956 Linc & Cont
R-1161A         28        1956 Ford & Merc 312
R-1161-1A      28        1956 Ford & Merc 312
R-1161-2A      28        1956 Ford & Merc 312
R-1162A         28        1956 Ford & Merc 292
R-1162-1A      28        1956 Ford & Merc 292
R-1162-2A      28        1956 Ford & Merc 292
R-1163A         28        1956 Thunderbird 292
R-1163-1A      28        1956 Thunderbird 292
R-1163-2A       28       1956 Thunderbird 292
R-1164A         28        1956 Thunderbird 312
R-1164-1A      28        1956 Thunderbird 312
R-1164-2A      28        1956 Thunderbird 312
R-1268A          28       1956 Ford T.B. HiPerf, 2-4 Bbl Inst.
R-1434A         32        1957 Ford 2-4 Bbl. 312
R-1437A         32        1957 Ford 2-4 Bbl, 312
