May be looking for good used Air Cleaner complete for 1957 Thunderbird.
Posted By oldcarmark 2 Years Ago
May be looking for good used Air Cleaner complete for 1957...
Posted 2 Years Ago
Posts: 3.8K, Visits: 33.2K
Anyone have a real good Air Cleaner complete for 1957 Thunderbird. Regular 4BBL . Price? Thanks Ignore. Didn't buy the Car. Air Cleaner was least of what was wrong with Car. Thanks
carl
Posted 2 Years Ago
Posts: 1.2K, Visits: 20.7K
oldcarmark (8/14/2024)
might have one, I will check tomorrow,   Carl
carl
Posted 2 Years Ago
i don't have one, a friend has a repo 55,56 t bird air cleaner but probably different    Carl
Posted 2 Years Ago
Thanks. Didn't buy the Car
Skyliner57
Posted 2 Years Ago
Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)Supercharged (220 reputation)
Posts: 88, Visits: 9.3K
I have a TB air cleaner, the oil bath cleaner. I have some questions on how it is used etc. Is there an expert out there that I communicate with? Mine does not have the cork, I can add that. Not sure how high it is above the metal? I am also wondering about the actual orientation of the top to the lower part, looks like a louver molded into the top?
Is the top unit held down with a wing nut, larger one, washer? Any help would really be great.
Harold
was
Posted 2 Years Ago
Posts: 1.9K, Visits: 195.0K
Skylines, get a Thunderbird supplier catalog. Casco or Larry’s Thunderbird, whoever. They make repro air cleaners, but also the cork, staples etc. the pictures in the catalog (which you might find on line) will answer a lot of your questions.
Putting your location in your signature line helps.
Posted 2 Years Ago
Posts: 2.0K, Visits: 306.6K
"I have a TB air cleaner, the oil bath cleaner. I have some questions on how it is used etc."
Are you using it on a BIRD or FORD? Being an original oil bath, it should be valuable.
CLICK - https://www.npdlink.com/1955-1957-thunderbird/air-fuel/air-cleaner
Skyliner57
Posted 2 Years Ago
Thanks for link for the air cleaner. It is an oil bath. I will use on a 56 Victoria, which may have a 312.
If I buy the filter on the site you gave me will it fit?
I am not sure how to orient the top in relation to the bottom?
Thanks again.
Posted 2 Years Ago
"If I buy the filter on the site you gave me will it fit?"
Are you thinking of converting it to a dry style with paper filter?
I would consider the value of the original filter assy. Maybe sell it to someone who wants a dead nuts-on OEM and buy a  repro for the FORD dress-up kit?
BTW - You might not need that cork deflector as it was only used on the BIRD to prevent weather/fan wash from hitting the ACL through the hood scoop possibly ingesting rain/snow.
Also, the bottom plate is different between the 55 and 56 for choke clearances. The 56 ACL will work on either year (55/56 with OEM carb). What carb style are you using on your 57 FORD?
I will show position photos when you decide how you want to go.
Lou
Posted 2 Years Ago
Last Active: 4 Months Ago
Posts: 564, Visits: 8.4K
A   oil bath air cleaner is the best design ever made, that why it is still used on big trucks and off road vehicles.
